Latency Gains using TensorRT
Recently I am trying N:M pruning methods to see the gains in models such as Torchvision ResNet50 or ViT using TensorRT python library. Currently the setting I have -
GPU - A100/H100
Batch Size - 128/256
Pruning Method - ASP
Using Int8/FP16 with calibration data as ImageNet1k
After using this the gains that I am getting for - Sparse_TRT/Dense_TRT is -
For ResNet50
FINAL COMPARISON (mean latency, TRT unless --skip-tensorrt)
Method Mean (ms) p99 (ms) Throughput Speedup vs dense
Dense 36.787 37.120 6959.0 1.000x
ASP 2:4 36.520 36.790 7009.8 1.007x
For ViT-B/16
Dense 66.534 67.475 3847.6 1.000x
ASP 2:4 55.680 56.360 4597.7 1.195x
I am not sure if these numbers are expected like this or they should be more higher. I have also tried normal N:M sparsity just to see if there is any latency gains and the numbers are almost similar.
Please help me to understand if these make sense or not
Regards
Hi @s.priyadarshi629, thanks for sharing the dense vs sparse numbers. These results are plausible, especially the split you are seeing: almost no gain on ResNet50, and a more visible gain on ViT-B/16.
The main thing to keep in mind is that 2:4 sparsity is not a model-level 2x switch. TensorRT can only use sparse tactics on layers whose weights satisfy the 2:4 pattern, whose shapes map well to sparse kernels, and whose runtime is a large enough part of the full network. If the sparse-eligible layers are not the bottleneck, the end-to-end speedup can be small even when the pruning itself is correct.
For your two examples, the direction makes sense:
Model Your result How I would read it
ResNet50 ~1.007x Very possible if dense convs are already fast, if non-sparse layers dominate, or if TensorRT is not selecting many sparse tactics.
ViT-B/16 ~1.195x More believable because the larger GEMM / projection layers tend to expose sparse Tensor Core gains more cleanly.
I would debug this in three steps.
1. Confirm TensorRT is actually using sparse tactics
For an accuracy-preserving run, use the pruned ONNX and --sparsity=enable, not --sparsity=force. force is useful only as a quick performance ceiling because it can rewrite weights and does not preserve accuracy.
trtexec \
  --onnx=asp_resnet50.onnx \
  --fp16 \
  --sparsity=enable \
  --verbose \
  --buildOnly \
  2>&1 | tee sparse_build.log
If you are building through the TensorRT Python API, make sure the builder config has sparse weights enabled:
config.set_flag(trt.BuilderFlag.SPARSE_WEIGHTS)
Then check the verbose log for how many layers are eligible for sparse tactics and how many sparse tactics are selected.
2. Compare the per-layer profiles, not just the final mean latency
Run dense and sparse with the same precision, same input shape, same batch size, and the same timing setup:
# Dense baseline
trtexec \
  --onnx=dense_resnet50.onnx \
  --fp16 \
  --sparsity=disable \
  --shapes=input:128x3x224x224 \
  --useCudaGraph \
  --noDataTransfers \
  --profilingVerbosity=detailed \
  --dumpLayerInfo \
  --dumpProfile \
  --exportLayerInfo=dense_layers.json \
  --exportProfile=dense_profile.json \
  2>&1 | tee dense.log
# ASP / sparse run
trtexec \
  --fp16 \
  --sparsity=enable \
  --useCudaGraph \
  --noDataTransfers \
  --dumpLayerInfo \
  --dumpProfile \
  --exportLayerInfo=sparse_layers.json \
  --exportProfile=sparse_profile.json \
  2>&1 | tee sparse.log
Replace input:128x3x224x224 with the real input tensor name and shape from your model.
3. Measure FP16 and INT8 separately
Sparse FP16 and sparse INT8 do not always show the same end-to-end delta. INT8 dense kernels can already be fast, and calibration / Q-DQ placement can change which layers dominate the profile. I would first get a clean FP16 sparse-vs-dense comparison, then repeat the same profile comparison for INT8 after the calibration path is fixed.
One data point that would help: can you paste the verbose sparsity summary plus the top --dumpProfile rows for one ResNet50 run, dense vs ASP, at batch 128? That will show whether the issue is “sparse tactics are not being selected” or “sparse tactics are selected, but the model bottleneck moved somewhere else.”
Thanks,
Atharva
