I have an application that is rendering frames on gtkgl area. I want that gtk app to run on fullscreen(1920x1080), So for that I used xrandr also there is one requirement that we should remove all the stock icons , title bar from ubuntu os So for doing that we used openbox and we are able to do that also, but we faced an issue where we are getting image tearing, In order to fix that we followed one of the posts “openlGL fullscreen 'tearing' - #10 by hoanganhv1svm” (Option “ForceFullCompositionPipeline” “on”) But by applying this patch we found out that latency has increased significantly what can be done to fix this. We want to fix image tearing issue but at same point we don’t want that latency should go high
Thankyou
