Dear all:
From Volkov’s paper,
Vasily Volkov, James W. Demmel, Benchmarking GPUs to Tune Dense Linear Algebra. In SC ’08: Preceedings of the 2008 ACM/IEEE conference on Supercomputing.
Piscataway, NJ, USA, 2008, IEEE Press.
( can be obtained in the thread http://forums.nvidia.com/index.php?showtopic=89084 )
authors show that latency of shared memory of 8800GTX is 36 cycle, see figure 1
figure 1:
I try to find latency of shared memory of Tesla C1060, and the experimental result shows
latency of shared memory is 34 cycle.
The procedures of my experiment is:
I modify code in cuda_latency.tar.gz provided by @Sylvain Collange in the thread
http://forums.nvidia.com/index.php?showtop…rt=#entry468968
The kernel is
#define SMEM_SIZE 256
static __global__ void smem_latency(int * data, timing_stats * timings)
__shared__ float b[SMEM_SIZE];
int threadNum = threadIdx.x;
volatile unsigned int start_time = 1664;
volatile unsigned int end_time = 1664;
#pragma unroll 1
for (int i = 0; i < SMEM_SIZE; ++i){
b[i] = data[i];
__syncthreads();
int k = 0;
for( int j = 0; j < 2; j++){
start_time = clock();
#pragma unroll
k = b[k];
end_time = clock();
__syncthreads();
timings[threadNum].start_time = start_time;
timings[threadNum].end_time = end_time;
if ( 0 == threadNum ){
timings[1].start_time = k;
and execution configuration is 1 grid and 1 thread
dim3 grid(1, 1, 1);
dim3 threads(1, 1, 1);
smem_latency<<< grid, threads >>>(data_gpu, timings_gpu);
The result is 58 cycle. ( this is bigger than 36 cycle )
However if we use decuda to deassembly .cubin file, then
int k = 0;
#pragma unroll
k = b[k];
end_time = clock();
__syncthreads();
would be decoded as
label1: mov.b32 $r2, %clock
shl.u32 $r2, $r2, 0x00000001
movsh.b32 $ofs1, $r3, 0x00000002
cvt.rzi.s32.f32 $r3, s[$ofs1+0x0020]
mov.b32 $r4, %clock
shl.u32 $r4, $r4, 0x00000001
add.b32 $r1, $r1, 0x00000001
set.ne.s32 $p0|$o127, $r1, c1[0x0004]
@$p0.ne bra.label label1
bar.sync.u32 0x00000000
we can compare source code with result of decuda and find relationship between them,
r1 <-- 0 is variable “jâ€
r3 <-- 0 is variabel “kâ€
r2 = start_time <--%clock x 2
$ofs1 <-- k * sizeof(int)
r3 <-- b[k]
r3 <-- b[k]
r4 = end_time <-- %clock x 2
This means that “k = b[k]” has two instructions
S1 : $ofs1 <-- k * sizeof(int)
S2 : r3 <-- b[k]
and its Gatt chart is shown in figure 2.
figure 2:
but latency of shared memory should be execution time of instruction 2,
we have known pipeline latency of MAD is 24 cycle, so execution time of S2 is 58 - 24 = 34 cycle,
which is latency of shared memory.
