Latest Dashboard Update Issue: Peripherals not recognized. Solved?
The September update appeared to fetch the new firmware, and then do its reboot. I know from postings here, you just need to be patient and let it do its thing even if it appears hung. After 2 hours of black monitor-screen, I did a long-press power-off & unplug. The hard reset brought it back to life. Most of the updates went through according to the dash. After powering down again, it took another hard-reset to bring it back to life.
Well… a hard-reset doesn’t work anymore!
More background: Since the July update, the dash reported that I needed the driver version 610.43.02 for enhanced Out-of-Memory handling, which finally got cleared with the September update. Additionally, there is some sort of phantom notice about upgrading to driver 580.159; however, I already had 580.173. That notice doesn’t clear.
Anyone else having bricking issues?
I think I figured it out and offer the following to the group:
After reading the thread about KVM and USB Hubs, I reverted my setup to primitive peripherals (HDMI, wired mouse & keyboard). Wouldn’t you know it? Its functional again. I have a theory that perhaps someone can debunk or validate. Since I prefer hardware administration over network administration, I have been using a quality KVM. All was fine for about a month, until I used the KVM’s virtual USB to back up some of my recipes. The mount & transfer went fine and it seems the mount survives DGX power down. No issues with on/off cycles until I unmounted the KVM’s virtual USB. Now the KVM sits unused. Is this related to the other user’s nested USB issue? Am I connecting dots that shouldn’t be? Could one of you network guys offer an explanation/solution? Is this something that NVIDIA can fix with firmware?
So your issues cleared after you stopped using the KVM? What model of KVM were you using?
I decided to replace the HDMI cable. I am happy to report that its working well. The problem was either one or both of the following: 1) bad cable, or 2) improper seating of the pin connector.
