Dear @s.sato,
VPI is not supported on DRIVE AGX. You may check using DW/NVMedia APIs for your application. Do you see any required algorithms/operations are missing in NVMedia/DW APIs?
Dear @s.sato,
Could you please check <PATH_TO_DRIVESW 10.0 doc_folder>/DRIVE_Software/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide/NvMedia/nvmedia_concept_vpi.html#
I know nvmedia_concept_vpi, but I can’t find Backend Support table and how to implement some algorisms on PVA/VIC. Could you let me know where I can see them?
Dear @s.sato,
All the algorithms in the Vision programming page make use of PVA as backend. Note that PVA/VIC is accessed only via NvMedia APIs. It can not be programmed directly like GPU.
If you see any functionalities are missing in APIs, Please file a bug, requesting the feature. Our Engineering team will review your request.
Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs->Submit a new bug to file bug.
Please share ID here to follow up. Thanks
