One of the purposes of my pathtracer is to calculate the amount of light that falls on each face of a mesh.
Currently it computes direct illumination in one launch, then it calculates the indirect lighting by sampling the hemisphere across multiple launches so as to avoid a possible timeout error.
The mesh is pretty much a plane so one can get a width and height value based on the number of rows in the polygon and number of polygons per row. The width and height are then used as input for a 2D launch.
Now I am considering the possibility of making a 3D launch with the depth value corresponding to the number of hemisphere samples; that way the sampling can be done in parallel.
But now I’m concerned about the possibility of having many many threads could potentially cause a timeout error, because my 2D launch can be like 1024 by 1024 and I’m considering the depth value to be at least 256.
