I don’ t know how to fix it
Did you look at the FAQ section in the Kernel Profiling Guide :: Nsight Compute Documentation (search for “Could not deploy stock * files”) and try the suggestions?
Launched application returned 255 (0xff).
Based on this message looks like your application is failing. Make sure that your application runs correctly and the exit code is 0 without profiling.
I missed replies on the other post Profile python script with pytorch in linux target. Since the issue is the same we can track it at one place.
sure , I haved answer the new situation on that post
