Launch index x must be bigger than y?
Back at dealing with launch indexes. For our applications these can vary a lot.
I was getting these generic launch errors, which seem to go away if launch index x > Y
Is that really the case?
This is Optix 6
Edit: Nope, turns out the sum of the launch index can’t be more than 1 billion (2^30)
Hi tjaenichen,
You are correct: the total launch size for an OptiX launch is limited to 2^30 for performance reasons. Are you using a large launch for compute purposes, rather than rendering? Is this something you could use a CUDA launch for?
David.
Hi David,
it was just confusing, but I can easily work around this, without any large impact on performance. And yes, it’s for some complex light calculations that don’t render.
Cheers,
Thorsten
