I would like to launch a python program that uses GPU, CUDA, USB Camera, conv neural networks,… at startup. I tried to add the command to ‘Startup applications’: /bin/bash -c “sleep 15 && python3 /home/nvidia/program.py” but it doesn’t work.
Which interface do you use for camera? is it OpenCV?
If yes, please noticed that our default OpenCV package doesn’t enableGStreamer support.
You will need to re-build it from source:
[url]https://github.com/AastaNV/JEP/tree/master/script[/url]
Sorry, what I meant is that the command works on terminal but it doesn’t work if put on the « startup applications »: nothing still shows up at startup ».
So the problem isn’t resolved. Sorry for the confusion with my last message.
Best regards,
