Launching simultaneous parabricks jobs fail
I have installed Parabricks version 3.0 and I am testing it with singularity. I can run a job at a time successfully, both on a single GPU and on multiple GPUs.
However, I am unable to unable to run two simultaneous jobs of parabricks, getting the following error:
FATAL:   error while locking ext3 overlay partition from /sw/csgv/parabricks/3.0.0.2/gpu/extended_license/parabricks/parabricks/pb-overlay.img: can't open /sw/csgv/parabricks/3.0.0.2/gpu/extended_license/parabricks/parabricks/pb-overlay.img for writing, currently in use by another process
Could not run fq2bam
Exiting pbrun ...
The intent is to install Parabricks as a module in a shared space on a cluster for easy of access for multiple user.
Hello Mohsin,
Thanks for your interest in Parabricks and apologies for the troubles/inconvenience. There’s a limitation with Parabricks at the moment which will require you to copy the installation directory for each run and install with the --disable-fakeroot flag. That way you should be able to do multiple runs without any issue using singularity.
Hope this helps.
