I have installed isaac SDK and its dependencies on Jetson Xavier (ubuntu 18.04, 64 bit). I have “bazelrc” file inside isaac > sdk directory. I tried to run the following command “bazel run …/zed_camera”. It says “bash: bazel command not found”. Then I separately tried to install bazel following the documentation of Nvidia bazel installation which are like the following:
sudo apt install curl gnupg
curl -fsSL https://bazel.build/bazel-release.pub.gpg | gpg --dearmor > bazel.gpg
sudo mv bazel.gpg /etc/apt/trusted.gpg.d/
echo “deb [arch=amd64] https://storage.googleapis.com/bazel-apt stable jdk1.8” | sudo tee /etc/apt/sources.list.d/bazel.list
sudo apt update && sudo apt install bazel
After this command I am getting an error : Unable to locate package bazel.
In the “Home>bin directory” I have a file bazel which is locked. Does it something to do with my problem? Please help.
