i am very new to GPU computing and i use Visual Studio 2008 with SDK Version 3.2.
I am wondering if it is correct to get linking errors when calling for example cudaMalloc() from a .cpp file.
If yes, all calls to the CUDA runtime API need to be done from .cu files, correct?
I keep the CUDA parts of my projects separate as I’ve found that some libraries do not play well when used from nvcc, while linking together with nvcc-generated code worked fine. Just so I won’t find myself in the position that some library suddenly does not work together with CUDA anymore and the CUDA code is spread all over the project.
