Can you tell me the location for libcuda.dylib in CUDA2.3 SDK
On my machine it is in /usr/local/cuda/lib
There is a problem with the installer.
You need to install the toolkit and then the driver, otherwise the toolkit installer will wipe out libcuda.dylib (part of the driver installation).
so for CUDA2.3 the intsllation procedure is
install CUDA2.3 Toolkit, then Drivers and then CUDA2.3 SDK. right?
or what could be the installation procedure? which one I have to install first?
Anyone know how to fix having to reinstall the driver every time I reboot? I can’t seem to get the settings to stick.
Solved here.
