LED for eMMC
I want to use a LED indicator to show the eMMC is working(Like HDD LED blinking).
However, it looks no pin from Jetson Nano/Jetson Xavier NX for this feature.
Is it possible to use a GPIO to achieve this one?
Wayne.
hello wayne_liao,
did you need LED blinking for read/write files?
may I have more details about what exactly you need for “to show the eMMC is working”,
thanks
Hi Jerry,
Yes, LED blinking for eMMC read/write files.
hello wayne_liao,
you may have some implementation to trigger high/low for GPIO pins in the memory controller.
please check Xavier Technical Reference Manual, you should refer to [Chapter-10 Low-Speed I/O]—> [SDMMC Controller] for more details.
please also refer to Topic 144550, for several ways to access GPIOs. such as, kernel APIs, python scripts, C++ samples.
thanks
Hi Jerry,
Got it,
Thanks for the information.
Wayne
Sorry, another question.
It is the same way to implement this feature in Jestson Nano?
Wayne
hello wayne_liao,
please have implementation in the memory controller,
I’ve never tired this before, but it should works by trigger GPIO state changes from kernel side to have LED blinking.
thanks
Hi Jerry,
OK, we will try it.
Thanks a lot.
Wayne.
