LED warning light for Jetson Nanon
Hi, I would like to add a LED warning light on a jetson nano and when an event occurs, the board can turn on the LED warning light. The jetson nano also includes a camera module recording all time. An example of LED warning light is this one.
Any clue?
This should be posted in the Jetson category, I will move it over to the Nano forum so support has visibility.
Tom K
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Hi @kayccc, yes, I still need help on that. Thanks
What interface do you want to use?
Is such example helpful for your case?
I need to trigger a bigger light visible few meters away even under poor visibility conditions. I was thinking about this kind of light. Snap-in LED Red 3-6 Volt for Raspberry Pi rack mount - MyElectronics. Iā€™m wondering if Jetson Nano can handle such component. Wrt the interface, it could use both GPIO or USB interface.
GPIO should handle that.
