Hi guys,
I am having problem getting the GPU work even though it shows that the latest driver is successfully installed.
The display output either works solely on HDMI output when I use the X11 or it works solely on main screen when I use the Wayland.
On Wayland when I run nvidia-settings, I get this message:
ERROR: Unable to find display on any available system
When I run nvidia-smi, I get this:
| NVIDIA-SMI 430.50 Driver Version: 430.50 CUDA Version: 10.1 |
| 0 GeForce GTX 1060 Off | 00000000:01:00.0 Off | N/A |
| N/A 49C P8 2W / N/A | 0MiB / 6078MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
I would highly appreciate if you could help me fix this issue and make the GPU work.
nvidia-bug-report.log.gz (1.1 MB)
