I have a Lenovo Quadro T61P with an Nvidia quadro 570M GPU. From Lenovo the latest driver is Forceware 177.15.
I have tried Cuda v2.1 and Cuda v2.0, both with mixed results. Simple applications work,
eg deviceQuery.exe gives -
There is 1 device supporting CUDA
Device 0: “Quadro FX 570M”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 268107776 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.95 GHz
Concurrent copy and execution: Yes
Test PASSED
and simple examples work however most of the supplied projects do not work. For example bitonic.exe gives an error -
cutilCheckMsg() CUTIL CUDA error: Kernel execution failed … line 79 invalid device function
line 79 is a simple value assignment so I don’t think that is it.
I see the version numbers for the supported drivers are not the same as the Lenovo driver, however I couldn’t get aything else to install.
Does anyone know if that is the problem ? and if so will version 1.0 work ? or is there something else I can try ?
jcb
