I go following error message
/lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
How to solve this issue?
I see same issue in below post but there are differences. This issue is libGLdispatch.so.0
and that issue is libgomp.so.1
See:
Did you try :
LD_PRELOAD=/lib/aarch64-linux-gnu/libGLdispatch.so <your_app>
I used following code,
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libGLdispatch.so.0:$LD_PRELOAD
rm ~/.cache/gstreamer-1.0/ -fr
Then tonny IDE is working but VS Code not working. I use code --no-sandbox
command to run.
I also try your command like following,
LD_PRELOAD=/lib/aarch64-linux-gnu/libGLdispatch.so code --no-sandbox
and
It is not working for VS Code.
I don’t have experience with such case, but you may see if you are using an envFile that would overide the current env, or try to create one:
system
Closed
5
