I flashed Drive SW 10.0 to Drive Xavier through SDKmanager, and I have been trying to install some application sw. But run into this problem: /lib/modules/4.14.102-rt53-tegra/build: No such file or directory. I also checked /usr/src. It is empty. Wonder if I need to build the kernel after flash the platform, but how?
Could you try to copy to either Xavier A or B accordingly as below?
sudo cp -a ${PWD}/out-t186ref-linux/lib/modules/* <top>/drive-t186ref-linux/targetfs_a/lib/modules/
sudo cp -a ${PWD}/out-t186ref-linux/lib/modules/* <top>/drive-t186ref-linux/targetfs_b/lib/modules/
Thank you VickNV!
one question, here, the “” in "sudo cp -a ${PWD}/out-t186ref-linux/lib/modules/* /drive-t186ref-linux/targetfs_a/lib/modules/ " should be the directory in Xavier or host pc?
After I flashed the Xavier, I saw the the “build” folder under /lib/modules/4.14.102-rt53-tegra/ on Xavier. But it links to the kernel file on the host machine because that is where it was built. I tried to copy the kernel file to the Xavier, and rebuilt the link, but it gave me some other errors. I guess I need to install the kernel header files instead of a direct copy and paste. Would you please advise the next step?
The error message is /bin/sh: 1: scripts/basic/fixdep: Exec format error. I searched on line, looks like that the executable was built on the host instead of on the target, it suggests recompiling on the target.
I guess this should be a common issue of cross compiling linux kernel (maybe something wrong in makefile) but not nvidia specific. Could you follow other community people’s guidance to fix it? Thanks!
Please check comment #4 of this topic. You can access them on your host system after completing download/installation process of DRIVE Software via SDM Manager.Thanks!
