Hi! I’m having a little bit of trouble with a libargus application I’m coding up. I’ve attempted to follow the pattern used in the /usr/src/jetson_multimedia_api/argus/samples/
directory, but the code does not produce any images, and I’m sort of at a loss for what to do to make it produce images.
I am trying to create two image producers, one for each camera on my Jetson. Correspondingly, I create two consumers, attach one to each producer, then attempt to draw images from them. But when I try to call acquireImage()
on those two IFrameConsumers
(line 134), the application hangs. Not only that, but it appears to take up gobs of memory, and if left long enough it consumes all of RAM.
I’ve tried to follow the conventions of the sample code as best as possible by initializing all of my objects where the sample code does, to no avail. I cannot find documentation about what might be going wrong, so I was hoping someone here could point me in the right direction, at least towards some documentation I could read about acquireImage()
and IFrameConsumers
Attached is the libargus application. It is also a ROS node, but that is a secondary detail and doesn’t affect the code much (as far as I can tell).
mipi_libargus_driver.cpp (12.1 KB)
