Libargus - Multiple CSI cameras still show same module string
Just bumping this issue as it’s still a problem in JP5.1
While someone is looking at this, the Argus.h types specify a MAX_UUID_NAME_SIZE of 32 bytes but the sensor placement strings are longer than this. Please could someone increase the limit or decrease the length of the names?
@eh-steve
J5.1.1 should have the fixed.
The moduleString bug is indeed fixed in 5.1.1, but
const uint32_t MAX_UUID_NAME_SIZE = 32;
is still present in Argus/UUID.h, while the UUIDs in Argus/Types.h have names which are longer than 32 bytes.
Suppose yes.
Please follow the MAX_UUID_NAME_SIZE
Is this aimed at me? The libargus headers maintained by nvidia need to be updated?
I mean the size is enough. Why do you need longer strings?
These UUID definitions are in the file supplied by nvidia (in file /usr/src/jetson_multimedia_api/include/Argus/Types.h):
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_REAR_OR_BOTTOM_OR_BOTTOM_LEFT, 01dba8b0,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_FRONT_OR_TOP_OR_CENTER_LEFT,   01dba8b1,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_CENTER_OR_CENTER_RIGHT,        01dba8b2,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_TOP_LEFT,                      01dba8b3,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_BOTTOM_RIGHT,                  01dba8b4,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_TOP_RIGHT,                     01dba8b5,1946,11eb,8b6f,08,00,20,0c,9a,66);
DEFINE_UUID(SensorPlacement, SENSOR_PLACEMENT_UNKNOWN,                       01dba8b6,1946,11eb,8b6f,08,00,20,0c,9a,66);
Clearly SENSOR_PLACEMENT_REAR_OR_BOTTOM_OR_BOTTOM_LEFT is 46 characters which is longer than 32. This means that when you print this enum using getName(), it will be truncated to 32 characters (SENSOR_PLACEMENT_REAR_OR_BOTTOM_) which I doubt is the desired behaviour?
The moduleString bug is fixed any reason to use getName()?
