We’re using the Jetson Xavier NX platform with L4T 32.4.3 and using the Argus library to access the image stream from the camera.
- Is there a version mismatch between libargus in the documentation and what is deployed with L4T?
- How do we find the version of libargus that is described in the L4T documentation,
- How can we update the libargus library if we want to use that function, without upgrading our version of Jetpack?
Here is from r32.5(J4.5.x)
nvidia@dhcp-10-19-107-82:/usr/src/jetson_multimedia_api$ grep -ir setBayerHistogramRegion .
./argus/docs/doxygen/html/classArgus_1_1IAutoControlSettings.html:<tr class="memitem:ab4069e77b2fb5b8b2a254a36c980ca85"><td class="memItemLeft" align="right" valign="top">virtual <a class="el" href="namespaceArgus.html#a43dee5758547aaf78710c7c1fe122fe3">Status</a> </td><td class="memItemRight" valign="bottom"><a class="el" href="classArgus_1_1IAutoControlSettings.html#ab4069e77b2fb5b8b2a254a36c980ca85">setBayerHistogramRegion</a> (const <a class="el" href="classArgus_1_1Rectangle.html">Rectangle</a>< uint32_t > &region)=0</td></tr>
./argus/docs/doxygen/html/classArgus_1_1IAutoControlSettings.html: <td class="memname">virtual <a class="el" href="namespaceArgus.html#a43dee5758547aaf78710c7c1fe122fe3">Status</a> Argus::IAutoControlSettings::setBayerHistogramRegion </td>
./argus/docs/doxygen/html/Settings_8h_source.html:<div class="line"><a name="l00287"></a><span class="lineno"> 287</span>  <span class="keyword">virtual</span> <a class="code" href="namespaceArgus.html#a43dee5758547aaf78710c7c1fe122fe3" title="Status values returned by API function calls.">Status</a> <a class="code" href="classArgus_1_1IAutoControlSettings.html#ab4069e77b2fb5b8b2a254a36c980ca85" title="Sets the bayer histogram region of interest.">setBayerHistogramRegion</a>(<span class="keyword">const</span> <a class="code" href="classArgus_1_1Rectangle.html">Rectangle<uint32_t></a>& region) = 0;</div>
./argus/docs/doxygen/html/functions_func_0x73.html:<li>setBayerHistogramRegion()
./argus/docs/doxygen/html/search/functions_73.js: ['setbayerhistogramregion',['setBayerHistogramRegion',['../classArgus_1_1IAutoControlSettings.html#ab4069e77b2fb5b8b2a254a36c980ca85',1,'Argus::IAutoControlSettings']]],
./argus/docs/doxygen/html/search/all_73.js: ['setbayerhistogramregion',['setBayerHistogramRegion',['../classArgus_1_1IAutoControlSettings.html#ab4069e77b2fb5b8b2a254a36c980ca85',1,'Argus::IAutoControlSettings']]],
./argus/docs/doxygen/html/classArgus_1_1IAutoControlSettings-members.html: <tr><td class="entry"><a class="el" href="classArgus_1_1IAutoControlSettings.html#ab4069e77b2fb5b8b2a254a36c980ca85">setBayerHistogramRegion</a>(const Rectangle< uint32_t > &region)=0</td><td class="entry"><a class="el" href="classArgus_1_1IAutoControlSettings.html">Argus::IAutoControlSettings</a></td><td class="entry"><span class="mlabel">pure virtual</span></td></tr>
./argus/docs/doxygen/html/functions_0x73.html:<li>setBayerHistogramRegion()
./argus/include/Argus/Settings.h: virtual Status setBayerHistogramRegion(const Rectangle<uint32_t>& region) = 0;
./argus/apps/camera/docs/doxygen/html/Dispatcher_8cpp_source.html:<div class="line"><a name="l00650"></a><span class="lineno"> 650</span>  <span class="keywordflow">if</span> (<a class="code" href="classArgusSamples_1_1AutoControlSettingsObserver.html#ad77be17b865f804065a7b271766ad3b5">m_iAutoControlSettings</a>->setBayerHistogramRegion(histRegion) != Argus::STATUS_OK)</div>
./argus/apps/camera/modules/Dispatcher.cpp: if (m_iAutoControlSettings->setBayerHistogramRegion(histRegion) != Argus::STATUS_OK)
nvidia@dhcp-10-19-107-82:/usr/src/jetson_multimedia_api$ cat argus/RELEASE.TXT
Argus Camera API Release Notes
Release 0.97 (08/10/2018)
Hi Shane,
Thanks for the quick response. As I had mentioned before we are constrained on the L4T version and can’t upgrade to r32.5(J4.5.x)
. Is there a way to get this for L4T version 32.4.3?
Sorry, it involve many libs for the camera framework it’s could be better to upgrade to 32.5
