From the argus/samples/cudaHistogram/main.cpp example,
I’m interested in expanding this to access the (YUV420) UV plane in CUDA. We see a surface created for the Y plane:
// Create a surface from the luminance plane
CUDA_RESOURCE_DESC cudaResourceDesc;
memset(&cudaResourceDesc, 0, sizeof(cudaResourceDesc));
cudaResourceDesc.resType = CU_RESOURCE_TYPE_ARRAY;
cudaResourceDesc.res.array.hArray = cudaEGLFrame.frame.pArray[0];
CUsurfObject cudaSurfObj = 0;
cuResult = cuSurfObjectCreate(&cudaSurfObj, &cudaResourceDesc);
if (cuResult != CUDA_SUCCESS)
ORIGINATE_ERROR("Unable to create the surface object (CUresult %s)",
getCudaErrorString(cuResult));
and accessed via:
__global__ void histogram_smem_atomics(
CUsurfObject surface,
unsigned int width,
unsigned int height,
unsigned int *out)
surf2Dread(&data, surface, col, row);
We also see there is (what I assume is the UV plane) at cudaEGLFrame.frame.pArray[1] since there are 2 planes available.
The Y plane works fine, but I’m interested in knowing how the UV plane should be accessed within the 2D surface?
We create a seperate UV surface and pass it to CUDA in the same manner as the Y plane.
e.g. Is the U plane ‘width’ pixels wide by ‘height/4’ pixels high? Is it then followed by the V plane? or something else? In other words, what is the memory layout for the UV plane as a CUDA 2D surface (so we can read U and V values using surf2Dread with X,Y coordinates)?
