Initializing cameraProvider with the following code on Qt gives me the following output. What am I doing wrong here?
Output:
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 248: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[0].DetailGain=7.8"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 250: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[1].DetailGain=6.8"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 252: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[2].DetailGain=5.8"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 254: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[3].DetailGain=3.7"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 256: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[4].DetailGain=2.5"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 258: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[5].DetailGain=2.0"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 260: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[6].DetailGain=1.5"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 262: Error: Invalid isp config attribute: "detailenhancement.DynamicProps[7].DetailGain=0.7"
CAM: serial no file already exists, skips storing againLoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Argus Version: 0.96.2 (single-process)
Press <RETURN> to close this window...
Compiling the Argus samples worked fine, so I think it is probably the setting up of the environment in Qt that is not done properly.
Any idea what I am missing or how to further debug this?
