I am getting the
“ImportError: libcublas.so.9.0: cannot open shared object file: No such file or directory”
error when I call my application with “sudo python3.6 …” but not when I call just “python3.6 …”
elastic beanstalk uses “sudo”, so removing the command is not an option.
only CUDA 9.0 is installed (which is the correct version for our environment), and /usr/local/cuda/lib64/libcublas.so.9.0 exists .
we created a separate ec2 instance with the same config and same AMI ID: CUDA9ClassicAmazonLinuxDLAMIwithMXNetTensorflowandCaffe2, and had no issues. It seems to be an issue present only with the elastic beanstalk.
$LD_LIBRARY_PATH = ‘/usr/local/cuda/lib64:/usr/local/lib:/usr/lib:/usr/local/cuda/extras/CUPTI/lib64:/usr/local/mpi/lib:/lib/:/home/ubuntu/src/caffe2/build:/home/ec2-user/src/caffe2/build:/usr/local/cuda/lib64:/usr/local/lib:/usr/lib:/usr/local/cuda/extras/CUPTI/lib64:/usr/local/mpi/lib:/usr/local/cuda/lib64:/usr/local/lib:/usr/lib:/usr/local/cuda/extras/CUPTI/lib64:/usr/local/mpi/lib:/lib/:/home/ubuntu/src/caffe2/build:/home/ec2-user/src/caffe2/build:/usr/local/cuda/lib64:/usr/local/lib:/usr/lib:/usr/local/cuda/extras/CUPTI/lib64:/usr/local/mpi/lib:’
$PATH = ‘/usr/local/cuda/bin:/usr/local/bin:/opt/aws/bin:/usr/local/mpi/bin:/home/ubuntu/src/caffe2/build:/home/ec2-user/src/caffe2/build:/usr/local/cuda/bin:/usr/local/bin:/opt/aws/bin:/usr/local/mpi/bin:/usr/local/cuda/bin:/usr/local/bin:/opt/aws/bin:/usr/local/mpi/bin:/home/ubuntu/src/caffe2/build:/home/ec2-user/src/caffe2/build:/usr/local/cuda/bin:/usr/local/bin:/opt/aws/bin:/usr/local/mpi/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/aws/bin:/home/ec2-user/.local/bin:/home/ec2-user/bin’
any thoughts?
