Libcuda.so: file not recognized: File truncated when make during a docker build
Hi, I’m currently using nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples to build my own docker image. But I need to make my app during the build of this DockerFile with “RUN make” and it returns an error… Here is a simplified DockerFile (I know that some libs are missing) that gives the same error :
FROM nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
RUN apt-get update && apt-get update -y ; \
    apt-get install -y make ; \
    apt-get install -y libgstreamer-plugins-base1.0-dev ; \
    apt-get install -y libgstreamer1.0-dev ; \
    apt-get install -y libgstrtspserver-1.0-dev ; \
    apt-get install -y libx11-dev ; \
    apt-get install -y gcc ; \
    apt-get install -y git ; \
    apt-get install -y libjson-glib-dev ; \
    apt-get install -y libssl-dev ; \
    cd /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test5/ ; \
    sed -i 's/?=/:=10.2/g' Makefile ; \
    make
ENTRYPOINT /bin/bash
The error is :
/usr/bin/ld: cannot find -lcudart
/usr/bin/ld: cannot find -lnvdsgst_meta
/usr/bin/ld: cannot find -lnvds_meta
/usr/bin/ld: cannot find -lnvdsgst_helper
/usr/bin/ld: cannot find -lnvdsgst_smartrecord
/usr/bin/ld: cannot find -lnvds_utils
/usr/bin/ld: cannot find -lnvds_msgbroker
/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/libcuda.so: file not recognized: File truncated
collect2: error: ld returned 1 exit status
Makefile:71: recipe for target 'deepstream-test5-app' failed
make: *** [deepstream-test5-app] Error 1
The command '/bin/sh -c apt-get update && apt-get update -y ;     apt-get install -y make ;     apt-get install -y libgstreamer-plugins-base1.0-dev ;     apt-get install -y libgstreamer1.0-dev ;     apt-get install -y libgstrtspserver-1.0-dev ;     apt-get install -y libx11-dev ;     apt-get install -y gcc ;     apt-get install -y git ;     apt-get install -y libgstreamer-plugins-base1.0-dev ;     apt-get install -y libgstreamer1.0-dev ;     apt-get install -y libgstrtspserver-1.0-dev ;     apt-get install -y libx11-dev ;     apt-get install -y libjson-glib-dev ;     apt-get install -y libssl-dev ;     cd /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test5/ ;     sed -i 's/?=/:=10.2/g' Makefile ;     make' returned a non-zero code: 2
Here are the full logs :
logs.txt (109.5 KB)
Is this normal that the make cannot access to libcuda.so when building the DockerFile, but when running it with “ENTRYPOINT make” instead it works ?
I’m using :
Deepstream 5.1
Jetpack 4.5.1
I am having the same issue. Did you manage to resolve this problem?
Regards,
Patrick
I’m still having the problem… Even if it’s slower, I’m executing the “make” in an Entrypoint.
Hope someone will find a solution or an answer to this topic.
Hi, I did not run exactly the l4t deepstream to face this issue. I was using deepstream:5.1-21.02-triton when I encountered the same issue as you. When running make from docker build, it throws me the error upon reaching make portion. However, if I skip the make portion and only perform make when entering the docker container (via docker exec -it <> bash), it works.
Check if you have installed nvidia-container-runtime. If not, install using sudo apt-get install nvidia-container-runtime. Probably you need gpu access during docker build. Credits to https://stackoverflow.com/questions/59691207/docker-build-with-nvidia-runtime
Check if your docker default-runtime is set to nvidia in /etc/docker/daemon.json
    "runtimes": {
        "nvidia": {
            "path": "/usr/bin/nvidia-container-runtime",
            "runtimeArgs": []
    "default-runtime": "nvidia"
Alternatively, I found out that the libcuda.so in deepstream:5.1-21.02-triton image had different versions of libcuda.so, but not the -devel image. Hence, I switched to using deepstream:5.1-21.02-devel and it works find for me.
Further info on the difference:
In -devel image:
root@dd855203f1c8:~/src/plugins/gst-nvinfer# find / -name "libcuda.so"
/usr/local/cuda-11.1/targets/x86_64-linux/lib/stubs/libcuda.so
/usr/local/cuda-11.1/compat/libcuda.so
In -triton image:
/usr/lib/x86_64-linux-gnu/libcuda.so
Hope it helps.
Update:
The explanation to @Guitariout situation is due to the image expected GPU access via nvidia-container-runtime but the docker build is not using it. Therefore, the error appeared. However, when launching docker container via docker run --runtime==nvidia ..., the container has access to the GPU and able to make.
The culprit is due to /usr/lib/x86_64-linux-gnu/libcuda.so present in the image while using default docker runtime which was set to nvidia-container-runtime. First of all, ensure that the machine’s /etc/docker/daemon.json doesn’t have the default-runtime defined. Remove if it is present. Reload docker daemon and restart docker. To be safe, you can reboot your machine (I had to).
It should look like this :
    "runtimes": {
        "nvidia": {
            "runtimeArgs": []
Rebuild your Dockerfile again and you should be good to go.
Note:
You may try and see the difference in the presence of /usr/local/cuda-11.1/lib64/libcuda.so in nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples and your image. To avoid the error you are facing, /usr/local/cuda-11.1/lib64/libcuda.so should not be present.
