Jetson Linux 36.4 + Orin NX
after installing nvidia-jetpack successfully. libcudnn.so.8 is still not found
via@via-desktop:~$ sudo apt install nvidia-jetpack
[sudo] password for via:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
nvidia-jetpack is already the newest version (6.1+b123).
The following packages were automatically installed and are no longer required:
gdal-data libaec0 libarmadillo10 libarpack2 libavcodec-dev libavformat-dev libavutil-dev libblosc1 libcfitsio9 libcharls2 libdc1394-dev
libdeflate-dev libdouble-conversion3 libevent-core-2.1-7 libevent-pthreads-2.1-7 libexif-dev libfabric1 libfreexl1 libfyba0 libgdal30
libgdcm-dev libgdcm3.0 libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgl2ps1.4 libglew2.2 libgphoto2-dev libhdf4-0-alt libhdf5-103-1
libhdf5-hl-100 libheif1 libhwloc-plugins libhwloc15 libilmbase-dev libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjsoncpp25
libkmlbase1 libkmldom1 libkmlengine1 liblept5 libminizip1 libmysqlclient21 libnetcdf19 libodbc2 libodbcinst2 libogdi4.1
libopencv-calib3d4.5d libopencv-contrib4.5d libopencv-dnn4.5d libopencv-features2d4.5d libopencv-flann4.5d libopencv-highgui4.5d
libopencv-imgcodecs4.5d libopencv-imgproc4.5d libopencv-ml4.5d libopencv-objdetect4.5d libopencv-photo4.5d libopencv-shape4.5d
libopencv-stitching4.5d libopencv-superres4.5d libopencv-video4.5d libopencv-videoio4.5d libopencv-videostab4.5d libopencv-viz4.5d
libopenexr-dev libopenmpi3 libpmix2 libpng-dev libpq5 libproj22 libraw1394-dev librttopo1 libsocket++1 libspatialite7 libsuperlu5
libswresample-dev libswscale-dev libsz2 libtbb-dev libtesseract4 libtiff-dev libtiffxx5 libucx0 liburiparser1 libvtk9.1 libxerces-c3.2
libxnvctrl0 mysql-common proj-data unixodbc-common
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 179 not upgraded.
via@via-desktop:~$ python
Python 3.10.12 (main, Jul 29 2024, 16:56:48) [GCC 11.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import ultralytics
File “”, line 1, in
File “/home/via/.local/lib/python3.10/site-packages/ultralytics/init.py”, line 11, in
from ultralytics.models import NAS, RTDETR, SAM, YOLO, FastSAM, YOLOWorld
File “/home/via/.local/lib/python3.10/site-packages/ultralytics/models/init.py”, line 3, in
from .fastsam import FastSAM
File “/home/via/.local/lib/python3.10/site-packages/ultralytics/models/fastsam/init.py”, line 3, in
from .model import FastSAM
File “/home/via/.local/lib/python3.10/site-packages/ultralytics/models/fastsam/model.py”, line 5, in
from ultralytics.engine.model import Model
File “/home/via/.local/lib/python3.10/site-packages/ultralytics/engine/model.py”, line 8, in
import torch
File “/home/via/.local/lib/python3.10/site-packages/torch/init.py”, line 237, in
from torch._C import * # noqa: F403
ImportError: libcudnn.so.8: cannot open shared object file: No such file or directory
