This is my workflow:
I have setup the host PC with drivesoftware 10 ,
I have a code, that needs to be cross compiled for Drive AGX dev Kit.
I am using cmake, I have added all the library and header file links in the CMakeLists.txt file and updated in the source code accordingly.
When I do make -j, I am running into error :
bash-4.4$ make -j
[ 40%] Running C++ flatc compiler on /home/aswin/GMSL/ld-node-camera-gmsl/.devenv/host/share/flatbuffer/GenericMatrix3D.fbs
[ 40%] Running C++ flatc compiler on /home/aswin/GMSL/ld-node-camera-gmsl/.devenv/host/share/flatbuffer/Image.fbs
[ 80%] Building CXX object CMakeFiles/ld-node-camera-gmsl.dir/src/CameraGmsl.cpp.o
[ 80%] Building CXX object CMakeFiles/ld-node-camera-gmsl.dir/src/main.cpp.o
[100%] Linking CXX executable ld-node-camera-gmsl
/usr/local/driveworks-2.2/lib/libdriveworks.so: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/ld-node-camera-gmsl.dir/build.make:159: ld-node-camera-gmsl] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/ld-node-camera-gmsl.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
I have followed all the steps as given in the documentation.
I am a noobie to AGX, so please excuse me.
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
