I am missing libraries libGL.so and libGLU.so (and probably more) after installing the nvidia drivers.
I followed the linux installation guide to install nvidia-driver:470 and cuda-11-4 on my Rocky 8 system. I am using the package-manager version with network packages approach. I added the cuda-rhel8 repo and then installed the driver.
I noticed that neither dnf module install nvidia-driver:470 nor dnf module install nvidia-driver:470-dkms
install libGL.so or libGLU.so! What do I need to do to get the missing libraries?
Thanks for your reply!
I do have libglvnd, libglvnd-devel installed which provides /usr/lib64/libGL.so. AFAIK glvnd just dispatches to the correct libGL which seems to fail on my machine! When I run cuda applications with /usr/lib64/libGL.so I get errors that seem to relate to the use of missmatching libraries.
As an example: If I try to build the Cuda sample /usr/local/cuda/samples/2_Graphics/volumeRender I get a warning that libGL.so and libGLU.so were not found. And indeed in the search path /usr/lib64/nvidia there is no libGL.so:
If I modify the findgllib.mk script to link against /usr/lib64/libGL.so then the executable fails with: CUDA error at volumeRender.cpp:436 code=999(cudaErrorUnknown) "cudaGraphicsGLRegisterBuffer(&cuda_pbo_resource, pbo, cudaGraphicsMapFlagsWriteDiscard)"
Driver seems fine, nvidia-uvm is loaded. Looking at the sample code, I think GL is already initialized when the failure occurs. Please check for a general cuda issue by running the deviceQuery sample and post its output.
$ /usr/local/cuda/samples/1_Utilities/deviceQuery/deviceQuery
/usr/local/cuda/samples/1_Utilities/deviceQuery/deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Quadro K6000"
CUDA Driver Version / Runtime Version 11.4 / 11.4
CUDA Capability Major/Minor version number: 3.5
Total amount of global memory: 12204 MBytes (12796362752 bytes)
(015) Multiprocessors, (192) CUDA Cores/MP: 2880 CUDA Cores
GPU Max Clock rate: 902 MHz (0.90 GHz)
Memory Clock rate: 3004 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 1572864 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: No
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 104 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
The vnc session does not connect to the real Xserver on the nvidia but uses a virtual Xserver running software GL.
To use the nvidia gpu from remote, either use x11vnc/vnc0server or VirtualGL.
Thank you very much for pointing me to the right direction!
I was not aware, that my vnc server was creating a new virtual screen instead of using :0. I gave x11vnc a try and indeed the volumeRender sample now works without errors. As always the problem was sitting in front of the screen…
