kg99
October 28, 2020, 1:04pm
1
Jetson nano Jetpack 4.4.
I am using deepstream 5. I made a pipeline. Please see link for pipeline graph. pipeline graph .
Some images work but others do not work. This image taken from darknet yolo data gives segfault. The below image does not work.
https://filebin.net/bx3x8zqpdnjfkmtn/person.jpg?t=xd31pm38
But this one works for example. Please see url below.
https://filebin.net/tq77axdm2x3ry8nq/2.jpg?t=mu1sksfz
Below is the error I get.
All images submitted are jpegs.
What can possible be causing the behavior?
Why would it work on some images and not on others?
Thank you.
We have a sample demonstrating JPEG decoding:
deepstream-5.0\sources\apps\sample_apps\deepstream-image-decode-test
Please check if the issue can be reproduced by running the sample. Somehow we are not able to access filebin.net . You may zip the JPEGs and attach it.
kg99
November 3, 2020, 11:36am
4
im.zip (270.5 KB) im.zip (270.5 KB)
Attached is a zip with the images.
uses nv12decoder and not nvvideoconvert.
Please help provide the command for reproducing the issue.
