libgstreamer1.0 on R28.2
How can I install libgstreamer1.0 on R28.2?
nvidia@tegra-ubuntu:~$ sudo apt-get install -y libgstreamer1.0-0 libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libgstreamer1.0-0 is already the newest version (1.8.1-1~ubuntu1).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libgstreamer1.0-dev : Depends: libgstreamer1.0-0 (= 1.8.0-1) but 1.8.1-1~ubuntu1 is to be installed
                       Depends: gir1.2-gstreamer-1.0 (= 1.8.0-1) but 1.8.1-1~ubuntu1 is to be installed
E: Unable to correct problems, you have held broken packages.
It should already be installed:
gst-inspect-1.0 --version
gst-inspect-1.0 version 1.8.3
GStreamer 1.8.3
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
@Mohsen_UTD
I just in the same trouble with you! Did you find a way?
hello, Honey_Patouceul,
I know it has been already installed, but it seems it was not the right version. This problem blocked the install of Jetson Pack 3.2 on ubuntu 16.04! Would you please give me any advise?
See the answer of linuxdev to my other question. His response also solves this topic!
You should edit “sources.list” manually.
May I ask you a low-level question? Where is the “sources.list”? Haaaa
a text file in the following address:
/etc/apt/sources.list
Google it, you will find many tutorial and explanations
I found the sources.list by “cd /etc/apt/” and the content of the file is as follows:
[b]# deb cdrom:[Ubuntu 16.04.3 LTS Xenial Xerus - Release amd64 (20170801)]/ xenial main restricted
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu xenial main restricted
deb-src Index of /ubuntu xenial multiverse universe restricted main
Major bug fix updates produced after the final release of the
distribution.
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu xenial universe
deb-src Index of /ubuntu xenial universe
deb-src Index of /ubuntu xenial-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu xenial multiverse
deb-src Index of /ubuntu xenial-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu xenial partner
deb-src Index of /ubuntu xenial partner
deb Index of /ubuntu xenial-security main restricted
deb-src Index of /ubuntu xenial-security multiverse universe restricted main
deb Index of /ubuntu xenial-security universe
deb-src Index of /ubuntu xenial-security universe
deb Index of /ubuntu xenial-security multiverse
deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
[/b]
Then, how should I change?
See:
[url]https://devtalk.nvidia.com/default/topic/1031227/jetson-tx2/qt5-on-r28-2/post/5246271/#5246271[/url]
The last part of the post quotes a final sources.list. Any line which starts with a “#” is inert and invisible for configuration…it is a comment only. Look at the lines which are not comments…that is what you will want to enable everything. If you think a line shouldn’t be there just put a “#” in front of it and it will still be there for you to see, but inert.
Thank other users for sharing experience. Please also get help from gstreamer forum http://gstreamer-devel.966125.n4.nabble.com/
Really appreciated you reply. I am pretty confused by the sources.list because I am a novice when it comes to Ubuntu. I should follow the recommendations from you and Mohsen that using google to learn the basic knowledge. I will have a try by wholly replace my sources.list by yours. Any outcome will be reported!
Thanks again for you patient and kindness instruction!
