I just flash my sdcard and try run the sample deepstream-app but i got this error:
$ deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.802: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.805: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.809: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.811: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.817: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.823: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.837: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.839: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
(gst-plugin-scanner:11767): GStreamer-WARNING **: 17:22:16.842: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0: unsupported version 31073 of Verneed record
** ERROR: <create_multi_source_bin:1057>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1132>: create_multi_source_bin failed
** ERROR: <create_pipeline:1296>: create_pipeline failed
** ERROR: main:636: Failed to create pipeline
Quitting
App run failed
Any help pls?
