• Hardware Platform - Jetson AGX Xavier • DeepStream Version - DeepStream-l4t: 6.0.1-samples • JetPack Version - 5.0 dev • Issue Type - questions • Requirement details - How to build applications with GLIBC_2.31 dependencies using DeepStream-l4t as the base container
I tried buiding a deepstream application which was successfully built inside the deepstream-6.0:devel cpu container. Tried building the same application inside the deepStream-l4t:samples jetson container and it fails. checked the ldd and the version is 2.29. But this unknown libnvcolorutil.so requirs the GLIBC version 2.31. Any solutions?
Is there a deepstream-l4t:devel docker image available for jetson related developments?
My app runs without any issue inside deepstream-6.0:devel docker container running in a x86 server with T4 gpus. But it couldn’t build inside deepStream-l4t:samples docker container which I ran in Jetson AGX Xavier with Jetpack 5.0 installed.
I was able to build my deepstream application using Jetpack 4.6.2 stable release version and L4T base docker image. The issue was using the deepStream-l4t:base with Jetpack 5.0. Jetpack 5.0 which is a developer preview still don’t support deepStream-l4t:base containers. May be in future Deepstream newer version might support Jetpack 5.0.
