Hi.
I am trying to build the YOLOv4 Custom BBox Parser library (more info here) in a multistage docker container.
However, I am unable to access nvidia libraries provided by runtime: nvidia
during the docker image build.
My Dockerfile is as follows:
FROM nvcr.io/nvidia/deepstream-l4t:6.2-triton as libnvds_infercustomparser_builder
# Install Custom BBox Parser
# # Install Git LFS
WORKDIR /workspace
RUN curl -s https://packagecloud.io/install/repositories/github/git-lfs/script.deb.sh | bash
RUN apt-get install git-lfs
RUN git lfs install
WORKDIR /opt/nvidia/deepstream/deepstream/sources/
RUN git clone -b release/tao3.0_ds6.2ga https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps
WORKDIR /opt/nvidia/deepstream/deepstream/sources/deepstream_tao_apps
ENV CUDA_VER=11.4
RUN make
My docker-compose file is as follows:
services:
dev:
runtime: nvidia
container_name: dev
build:
context: .
entrypoint:
- /bin/sh
During RUN make
, I get the following output:
Building dev
[+] Building 2.6s (13/14)
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 3.81kB 0.0s
=> [internal] load metadata for nvcr.io/nvidia/deepstream-l4t:6.2-triton 2.0s
=> [auth] nvidia/deepstream-l4t:pull,push token for nvcr.io 0.0s
=> [ 1/10] FROM nvcr.io/nvidia/deepstream-l4t:6.2-triton@sha256:17e6c798d9772fa85d88594121fbdce9c4e25a94cf24196255ec08d49d5299f6 0.0s
=> CACHED [ 2/10] WORKDIR /workspace 0.0s
=> CACHED [ 3/10] RUN curl -s https://packagecloud.io/install/repositories/github/git-lfs/script.deb.sh | bash 0.0s
=> CACHED [ 4/10] RUN apt-get install git-lfs 0.0s
=> CACHED [ 5/10] RUN git lfs install 0.0s
=> CACHED [ 6/10] WORKDIR /opt/nvidia/deepstream/deepstream/sources/ 0.0s
=> CACHED [ 7/10] RUN git clone -b release/tao3.0_ds6.2ga https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps 0.0s
=> CACHED [ 8/10] WORKDIR /opt/nvidia/deepstream/deepstream/sources/deepstream_tao_apps 0.0s
=> ERROR [ 9/10] RUN make -C post_processor 0.6s
> [ 9/10] RUN make -C post_processor:
#0 0.418 make: Entering directory '/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_tao_apps/post_processor'
#0 0.427 deepstream-app: error while loading shared libraries: libnvdla_compiler.so: cannot open shared object file: No such file or directory
#0 0.428 g++ -o libnvds_infercustomparser_tao.so nvdsinfer_custombboxparser_tao.cpp -I/opt/nvidia/deepstream/deepstream-/sources/includes -I/usr/local/cuda-11.4/include -Wall -std=c++11 -shared -fPIC -Wl,--start-group -lnvinfer -lnvparsers -L/usr/local/cuda-11.4/lib64 -lcudart -lcublas -Wl,--end-group
#0 0.480 nvdsinfer_custombboxparser_tao.cpp:25:10: fatal error: nvdsinfer_custom_impl.h: No such file or directory
#0 0.480 25 | #include "nvdsinfer_custom_impl.h"
#0 0.480 | ^~~~~~~~~~~~~~~~~~~~~~~~~
#0 0.480 compilation terminated.
#0 0.504 make: Leaving directory '/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_tao_apps/post_processor'
#0 0.504 make: *** [Makefile:49: libnvds_infercustomparser_tao.so] Error 1
Dockerfile:43
41 | WORKDIR /opt/nvidia/deepstream/deepstream/sources/deepstream_tao_apps
42 | ENV CUDA_VER=11.4
43 | >>> RUN make -C post_processor
44 | RUN ls /usr/lib/aarch64-linux-gnu/tegra
45 |
ERROR: failed to solve: process "/bin/sh -c make -C post_processor" did not complete successfully: exit code: 2
ERROR: Service 'dev' failed to build : Build failed
During my exploration, I found that the directory /usr/lib/aarch64-linux-gnu/tegra/
does not exist during image build.
Should I omit the make
command, and run it in the started container, the command succeeds as it has access to the nvidia runtime. I don’t particularly want to have to do this as I want the resulting library file to be provided to the next stage of the docker container using a COPY --from= libnvds_infercustomparser_builder ...
command.
How do I run the make
command that depends on the nvidia runtime in the image build stage?
I appreciate any suggestion on how to overcome this problem.
Thanks in advance,
Nicholas
