I have just installed TensorRT-8.4.0.6
and I can’t seem to be able to run the sampleMNIST example.
Here the detailed info:
uname -a
Linux ip-<my ip> 5.4.0-1066-aws #69~18.04.1-Ubuntu SMP Wed Feb 9 15:36:54 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
CUDA: 10.2
cudNN: 8.3
Here what I have added to ~/.bashrc
# set env for TensorRT
export TENSORRT_DIR=$/home/ubuntu/TensorRT-8.4.0.6
export LD_LIBRARY_PATH=$TENSORRT_DIR/lib:$TENSORRT_DIR
Here what I have added to ~/.profile
# set PATH for cuda 10.2 installation
if [ -d "/usr/local/cuda-10.2/bin/" ]; then
export PATH=/usr/local/cuda-10.2/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
fi
Here what my TensorRT-8.4.0.6
looks like
I have already built the sample, so now when I execute make
from the directory I get the following
as a result, a
sample_mnist
file has been created inside /home/ubuntu/TensorRT-8.4.0.6/bin
.Inside the
/home/ubuntu/TensorRT-8.4.0.6/samples/sampleMNIST
I have created a mnist
folder with the requested images
How do I execute the sample now?
This is what I tried from within the /home/ubuntu/TensorRT-8.4.0.6/bin
directory
./sample_mnist --datadir=../samples/sampleMNIST/mnist --fp16
which raises
./sample_mnist: error while loading shared libraries: libnvinfer.so.8: cannot open shared object file: No such file or directory
Is this the right way to run the test sample?
If yes, am I just missing something super silly with PATHs?
