I am using TF-TRT with CUDA 11.0. I found that libnvrtc.so does not use rpath when opening “libnvrtc-builtins.so”.
Below is the strace of my program:
You see that libnvrtc only searches for libnvrtc-builtins in some system folders. But my program uses bazel to build and has a separate runfiles folder, which contains both “libnvrtc.so” and “libnvrtc-builtins.so”
[pid 8556] open(“tls/x86_64/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“tls/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“x86_64/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/etc/ld.so.cache”, O_RDONLY|O_CLOEXEC) = 23
[pid 8556] fstat(23, {st_mode=S_IFREG|0644, st_size=137517, …}) = 0
[pid 8556] mmap(NULL, 137517, PROT_READ, MAP_PRIVATE, 23, 0) = 0x7fdc9f1da000
[pid 8556] close(23) = 0
[pid 8556] access(“/etc/ld.so.nohwcap”, F_OK) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/usr/local/cuda-11.0/targets/x86_64-linux/lib/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/lib/x86_64-linux-gnu/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/usr/lib/x86_64-linux-gnu/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/lib/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] open(“/usr/lib/libnvrtc-builtins.so”, O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
[pid 8556] munmap(0x7fdc9f1da000, 137517) = 0
[pid 8556] write(2, “nvrtc: error: failed to open lib”…, 113nvrtc: error: failed to open libnvrtc-builtins.so.
Make sure that libnvrtc-builtins.so is installed correctly.
) = 113
