I tried every thing to install librosa in my jetson nx .. It didn’t work. even I installed llvmlite, librosa gets error with it. seems to be install torchaudio for jetson if there’s no way…
https://bagustris.wordpress.com/2020/07/09/how-to-install-numba-and-librosa-in-jetson-agx-xavier-ubuntu-18-04/
[How to install the Librosa library in Jetson Nano or aarch64 module – learninone.com]
indent preformatted text by 4 spaces
pip3 install librosa
Defaulting to user installation because normal site-packages is not writeable
Collecting librosa
Using cached librosa-0.8.0.tar.gz (183 kB)
Requirement already satisfied: audioread>=2.0.0 in ./.local/lib/python3.6/site-packages (from librosa) (2.1.9)
Requirement already satisfied: numpy>=1.15.0 in ./.local/lib/python3.6/site-packages (from librosa) (1.19.5)
Collecting scipy>=1.0.0
Downloading scipy-1.5.4-cp36-cp36m-manylinux2014_aarch64.whl (24.5 MB)
|████████████████████████████████| 24.5 MB 18 kB/s
Collecting scikit-learn!=0.19.0,>=0.14.0
Using cached scikit-learn-0.24.1.tar.gz (7.4 MB)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing wheel metadata … done
Requirement already satisfied: joblib>=0.14 in /usr/local/lib/python3.6/dist-packages (from librosa) (1.0.0)
Requirement already satisfied: decorator>=3.0.0 in /usr/lib/python3/dist-packages (from librosa) (4.1.2)
Collecting resampy>=0.2.2
Using cached resampy-0.2.2.tar.gz (323 kB)
Collecting numba>=0.43.0
Using cached numba-0.52.0.tar.gz (2.1 MB)
Collecting soundfile>=0.9.0
Using cached SoundFile-0.10.3.post1-py2.py3-none-any.whl (21 kB)
Requirement already satisfied: pooch>=1.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (1.3.0)
Collecting llvmlite<0.36,>=0.35.0
Using cached llvmlite-0.35.0.tar.gz (121 kB)
Requirement already satisfied: setuptools in /usr/local/lib/python3.6/dist-packages (from numba>=0.43.0->librosa) (52.0.0)
Requirement already satisfied: appdirs in /usr/local/lib/python3.6/dist-packages (from pooch>=1.0->librosa) (1.4.4)
Requirement already satisfied: packaging in /usr/local/lib/python3.6/dist-packages (from pooch>=1.0->librosa) (20.8)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from pooch>=1.0->librosa) (2.18.4)
Requirement already satisfied: six>=1.3 in ./.local/lib/python3.6/site-packages (from resampy>=0.2.2->librosa) (1.15.0)
Collecting threadpoolctl>=2.0.0
Using cached threadpoolctl-2.1.0-py3-none-any.whl (12 kB)
Collecting cffi>=1.0
Downloading cffi-1.14.4-cp36-cp36m-manylinux2014_aarch64.whl (206 kB)
|████████████████████████████████| 206 kB 241 kB/s
Collecting pycparser
Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
Requirement already satisfied: pyparsing>=2.0.2 in ./.local/lib/python3.6/site-packages (from packaging->pooch>=1.0->librosa) (2.4.7)
Building wheels for collected packages: librosa, numba, llvmlite, resampy, scikit-learn
Building wheel for librosa (setup.py) … done
Created wheel for librosa: filename=librosa-0.8.0-py3-none-any.whl size=202176 sha256=af31fca19e528b9683c2167108e9dbb16de6c8247c77856ff89a0d97ad6d9870
Stored in directory: /home/jetson/.cache/pip/wheels/32/2c/ce/86e49d4769aceba728421c24c0d726054bf4ca01175ff42bdd
Building wheel for numba (setup.py) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-7h5wg9cg/numba_c5cd6e246f5c4ee385bb623bc54f9c46/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-7h5wg9cg/numba_c5cd6e246f5c4ee385bb623bc54f9c46/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-1b6zp0_w
cwd: /tmp/pip-install-7h5wg9cg/numba_c5cd6e246f5c4ee385bb623bc54f9c46/
Complete output (877 lines):
Using Intel TBB from: /usr
Using OpenMP from: True
running bdist_wheel
running build
got version from file /tmp/pip-install-7h5wg9cg/numba_c5cd6e246f5c4ee385bb623bc54f9c46/numba/_version.py {‘version’: ‘0.52.0’, ‘full’: ‘18825058a6e32bb92f3941f3c8d14a818f19279f’}
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/numba
copying numba/_version.py → build/lib.linux-aarch64-3.6/numba
copying numba/init.py → build/lib.linux-aarch64-3.6/numba
copying numba/runtests.py → build/lib.linux-aarch64-3.6/numba
copying numba/extending.py → build/lib.linux-aarch64-3.6/numba
copying numba/main.py → build/lib.linux-aarch64-3.6/numba
creating build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/array_analysis.py → build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor_lowering_utils.py → build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor.py → build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/init.py → build/lib.linux-aarch64-3.6/numba/parfors
copying numba/parfors/parfor_lowering.py → build/lib.linux-aarch64-3.6/numba/parfors
creating build/lib.linux-aarch64-3.6/numba/scripts
copying numba/scripts/generate_lower_listing.py → build/lib.linux-aarch64-3.6/numba/scripts
copying numba/scripts/init.py → build/lib.linux-aarch64-3.6/numba/scripts
creating build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/main.py → build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/notebook.py → build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/init.py → build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/_runtests.py → build/lib.linux-aarch64-3.6/numba/testing
copying numba/testing/loader.py → build/lib.linux-aarch64-3.6/numba/testing
creating build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/structref.py → build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/init.py → build/lib.linux-aarch64-3.6/numba/experimental
copying numba/experimental/function_type.py → build/lib.linux-aarch64-3.6/numba/experimental
creating build/lib.linux-aarch64-3.6/numba/core
copying numba/core/caching.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ir_utils.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/dataflow.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/utils.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/withcontexts.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/decorators.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/bytecode.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/callwrapper.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/descriptors.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/intrinsics.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/interpreter.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/externals.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/registry.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/tracing.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/generators.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/callconv.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/pylowering.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/typeinfer.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cpu_options.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/debuginfo.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/sigutils.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/funcdesc.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/imputils.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler_lock.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/lowering.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/analysis.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/errors.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler_machinery.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/entrypoints.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/pythonapi.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/object_mode_passes.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/dispatcher.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/base.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ir.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/typed_passes.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/controlflow.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/optional.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/consts.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cpu.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/init.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/byteflow.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/postproc.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/inline_closurecall.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ssa.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/fastmathpass.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/environment.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/extending.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/options.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/removerefctpass.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/codegen.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/serialize.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/config.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/transforms.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/compiler.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/cgutils.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/boxing.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/untyped_passes.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/itanium_mangler.py → build/lib.linux-aarch64-3.6/numba/core
copying numba/core/ccallback.py → build/lib.linux-aarch64-3.6/numba/core
creating build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/stencilparfor.py → build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/stencil.py → build/lib.linux-aarch64-3.6/numba/stencils
copying numba/stencils/init.py → build/lib.linux-aarch64-3.6/numba/stencils
creating build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/gdb_hook.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/numba_entry.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/quicksort.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/appdirs.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/cffiimpl.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/inspection.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/init_utils.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/mergesort.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/dummyarray.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/special.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/timsort.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/dump_style.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/literal.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/findlib.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/init.py → build/lib.linux-aarch64-3.6/numba/misc
copying numba/misc/numba_sysinfo.py → build/lib.linux-aarch64-3.6/numba/misc
creating build/lib.linux-aarch64-3.6/numba/np
copying numba/np/arrayobj.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/linalg.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npyfuncs.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/ufunc_db.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npdatetime_helpers.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/extensions.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/numpy_support.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npdatetime.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/polynomial.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/init.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/npyimpl.py → build/lib.linux-aarch64-3.6/numba/np
copying numba/np/arraymath.py → build/lib.linux-aarch64-3.6/numba/np
creating build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_tracing.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jitclasses.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_datamodel.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nrt.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_byteflow.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_debuginfo.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_interproc.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_operators.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_alignment.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_help.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_compile_cache.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typenames.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_enums.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cli.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unsafe_intrinsics.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_range.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_func_lifetime.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_locals.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_threadsafety.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cache_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/complex_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_print.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_fastmath.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_api.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_listimpl.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_exceptions.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_methods.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/enum_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_buffer_protocol.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jit_module.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typedobjectutils.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_compiler_lock.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode_names.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mangling.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nan.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_random.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ssa.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_flow_control.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_stencils.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dyn_array.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/recursion_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeinfer.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_vectorization.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/compile_with_pycc.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dispatcher.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extending_types.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_indexing.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/dummy_module.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_hashing.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sets.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_entrypoints.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_jitmethod.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_generators.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_withlifting.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir_inlining.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/annotation_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_obj_lifetime.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_llvm_version_check.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_globals.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typedlist.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/parfors_cache_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_literal_dispatch.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/ctypes_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dummyarray.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_return_values.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numbers.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_pycc.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_debug.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_npdatetime.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/serialize_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cffi.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_copy_propagate.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_fancy_indexing.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_funcdesc.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_annotations.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dictimpl.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cfunc_cache_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ufuncs.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_conditions_as_predicates.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_inlining.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extended_arg.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dicts.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_init_utils.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_func_interface.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_num_threads.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_np_functions.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_heapq.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_attr.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_practical_lowering_issues.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_linalg.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/support.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ctypes.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cgutils.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_reductions.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numberctor.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/threading_backend_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_vectorization_type_inference.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_gil.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_function_type.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_config.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_exprs.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_intwidth.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_conversion.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_slices.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_looplifting.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_polynomial.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeconv.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_remove_dead.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_moved_modules.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_return.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_types.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/pdlike_usecase.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sys_stdin_assignment.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_analysis.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_recarray_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/overload_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_pipeline.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_tuples.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/orphaned_semaphore_usecase.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_multi3.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_boundscheck.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_iteration.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode_array.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dataflow.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numconv.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_try_except.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_blackscholes.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_caching.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/cffi_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numpy_support.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_listobject.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors_passes.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_recursion.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_chained_assign.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_record_dtype.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_gdb.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_make_function_to_jit_function.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_casting.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_struct_ref.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_errorhandling.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_storeslice.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_comprehension.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sort.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_wrapper.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/init.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_extending.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_constants.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_optional.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_runtests.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nested_calls.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_svml.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_overlap.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_support.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unicode.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_manipulation.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_object_mode.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_itanium_mangler.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_sysinfo.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_refop_pruning.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_lists.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dyn_func.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parallel_backend.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_parfors_caching.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mathlib.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_map_filter_reduce.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_codegen.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_builtins.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_cfunc.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_nrt_refct.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_iterators.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_profiler.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_closure.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_import.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_numpyadapt.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_complex.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typeof.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_errormodels.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_objects.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_python_int.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_asnumbatype.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_array_analysis.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir_utils.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_auto_constants.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/matmul_usecase.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mixed_tuple_unroller.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_serialize.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_typingerror.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_unpack_sequence.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_target_overloadselector.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_deprecations.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_warnings.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_dictobject.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_mandelbrot.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/error_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_maxmin.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/test_ir.py → build/lib.linux-aarch64-3.6/numba/tests
copying numba/tests/inlining_usecases.py → build/lib.linux-aarch64-3.6/numba/tests
creating build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/nvvmutils.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/decorators.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/device_init.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/mathimpl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/simulator_init.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/descriptor.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/args.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/models.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudaimpl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudadecl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/api.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/vectorizers.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdeviceimpl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/errors.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/initialize.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/intrinsic_wrapper.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/printimpl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/types.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/dispatcher.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevicedecl.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/testing.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/stubs.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cudamath.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevice.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/cuda_paths.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/random.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/init.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/libdevicefuncs.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/envvars.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/codegen.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/compiler.py → build/lib.linux-aarch64-3.6/numba/cuda
copying numba/cuda/target.py → build/lib.linux-aarch64-3.6/numba/cuda
creating build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/hsaimpl.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/decorators.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/mathimpl.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/dispatch.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/descriptor.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/api.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/vectorizers.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/initialize.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/hsadecl.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/stubs.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/init.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/gcn_occupancy.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/enums.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/codegen.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/mathdecl.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/compiler.py → build/lib.linux-aarch64-3.6/numba/roc
copying numba/roc/target.py → build/lib.linux-aarch64-3.6/numba/roc
creating build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/slicing.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/randomimpl.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/enumimpl.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/mathimpl.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/tupleobj.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/iterators.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/builtins.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/unicode_support.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/printimpl.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/heapq.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/numbers.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/cmathimpl.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/init.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/setobj.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/hashing.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/rangeobj.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/charseq.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/listobj.py → build/lib.linux-aarch64-3.6/numba/cpython
copying numba/cpython/unicode.py → build/lib.linux-aarch64-3.6/numba/cpython
creating build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/decorators.py → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/llvm_types.py → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/platform.py → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/init.py → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/cc.py → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/pycc/compiler.py → build/lib.linux-aarch64-3.6/numba/pycc
creating build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/init.py → build/lib.linux-aarch64-3.6/numba/cext
creating build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/dictobject.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typedobjectutils.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/listobject.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typedlist.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/init.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/typeddict.py → build/lib.linux-aarch64-3.6/numba/typed
copying numba/typed/dictimpl.py → build/lib.linux-aarch64-3.6/numba/typed
creating build/lib.linux-aarch64-3.6/numba/types
copying numba/types/init.py → build/lib.linux-aarch64-3.6/numba/types
creating build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/decorators.py → build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/base.py → build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/init.py → build/lib.linux-aarch64-3.6/numba/experimental/jitclass
copying numba/experimental/jitclass/boxing.py → build/lib.linux-aarch64-3.6/numba/experimental/jitclass
creating build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/packer.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/models.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/registry.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/testing.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/init.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
copying numba/core/datamodel/manager.py → build/lib.linux-aarch64-3.6/numba/core/datamodel
creating build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/registry.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_getitem.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_raise.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/static_binop.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/init.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
copying numba/core/rewrites/ir_print.py → build/lib.linux-aarch64-3.6/numba/core/rewrites
creating build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/type_annotations.py → build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/pretty_annotate.py → build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/annotations/init.py → build/lib.linux-aarch64-3.6/numba/core/annotations
creating build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/init.py → build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/bytes.py → build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/eh.py → build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/refcount.py → build/lib.linux-aarch64-3.6/numba/core/unsafe
copying numba/core/unsafe/nrt.py → build/lib.linux-aarch64-3.6/numba/core/unsafe
creating build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/castgraph.py → build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/typeconv.py → build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/init.py → build/lib.linux-aarch64-3.6/numba/core/typeconv
copying numba/core/typeconv/rules.py → build/lib.linux-aarch64-3.6/numba/core/typeconv
creating build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/setdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/listdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/cffi_utils.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/dictdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/builtins.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/randomdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/asnumbatype.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/arraydecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/ctypes_utils.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/npdatetime.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/bufproto.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/context.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/templates.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/init.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/enumdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/mathdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/npydecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/collections.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/cmathdecl.py → build/lib.linux-aarch64-3.6/numba/core/typing
copying numba/core/typing/typeof.py → build/lib.linux-aarch64-3.6/numba/core/typing
creating build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrtdynmod.py → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/context.py → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/init.py → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrtopt.py → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.py → build/lib.linux-aarch64-3.6/numba/core/runtime
creating build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/misc.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/iterators.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/common.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/containers.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/npytypes.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/abstract.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/init.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/function_type.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/functions.py → build/lib.linux-aarch64-3.6/numba/core/types
copying numba/core/types/scalars.py → build/lib.linux-aarch64-3.6/numba/core/types
creating build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/inspector.py → build/lib.linux-aarch64-3.6/numba/misc/help
copying numba/misc/help/init.py → build/lib.linux-aarch64-3.6/numba/misc/help
creating build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/array_exprs.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/parallel.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/decorators.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/ufuncbuilder.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/wrappers.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/deviceufunc.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/sigparse.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/dufunc.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
copying numba/np/ufunc/init.py → build/lib.linux-aarch64-3.6/numba/np/ufunc
creating build/lib.linux-aarch64-3.6/numba/np/unsafe
copying numba/np/unsafe/ndarray.py → build/lib.linux-aarch64-3.6/numba/np/unsafe
copying numba/np/unsafe/init.py → build/lib.linux-aarch64-3.6/numba/np/unsafe
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/source_module.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/init.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_distutils_nested.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
copying numba/tests/pycc_distutils_usecase/setup_setuptools_nested.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase
creating build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_literally_usage.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_jitclass.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_structref_usage.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_typed_list_usage.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_literal_container_usage.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_typed_dict_usage.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/init.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_examples.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
copying numba/tests/doc_examples/test_rec_array.py → build/lib.linux-aarch64-3.6/numba/tests/doc_examples
creating build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_ufunc_issues.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/cache_usecases.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_low_work.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_parallel_env_variable.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_errors.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_caching.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_gufunc.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/init.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_ufunc.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_dufunc.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
copying numba/tests/npyufunc/test_vectorize_decor.py → build/lib.linux-aarch64-3.6/numba/tests/npyufunc
creating build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/source_module.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
copying numba/tests/pycc_distutils_usecase/nested/init.py → build/lib.linux-aarch64-3.6/numba/tests/pycc_distutils_usecase/nested
creating build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/api.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/kernelapi.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/init.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/kernel.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/reduction.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
copying numba/cuda/simulator/compiler.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator
creating build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/runtime.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/devicearray.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/drvapi.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/libs.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/error.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/ndarray.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/init.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/driver.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/rtapi.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/enums.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/devices.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
copying numba/cuda/cudadrv/nvvm.py → build/lib.linux-aarch64-3.6/numba/cuda/cudadrv
creating build/lib.linux-aarch64-3.6/numba/cuda/tests
copying numba/cuda/tests/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests
creating build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/transpose.py → build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/init.py → build/lib.linux-aarch64-3.6/numba/cuda/kernels
copying numba/cuda/kernels/reduction.py → build/lib.linux-aarch64-3.6/numba/cuda/kernels
creating build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/runtime.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/devicearray.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/drvapi.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/init.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/driver.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/devices.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
copying numba/cuda/simulator/cudadrv/nvvm.py → build/lib.linux-aarch64-3.6/numba/cuda/simulator/cudadrv
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_frexp_ldexp.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_debuginfo.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_laplace.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_alignment.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_mandel.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_localmem.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_ipc.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_print.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_fastmath.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multithreads.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sm.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_complex.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array_methods.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multigpu.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_random.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_device.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_retrieve_autoconverted_arrays.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_dispatcher.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_datetime.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_globals.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_powi.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_slicing.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_reduction.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_debug.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_constmem.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array_args.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_userexc.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc_scalar.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_warp_ops.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_boolean.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_idiv.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_transpose.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_atomics.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc_scheduling.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_minmax.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_montecarlo.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_complex_kernel.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_errors.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_blackscholes.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_freevar.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_py2_div_issue.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_cuda_array_interface.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_forall.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_record_dtype.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_casting.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_libdevice.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_device_func.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_operator.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_gufunc.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_nondet.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sync.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_compiler.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_inspect.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_multiprocessing.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_optimization.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_exception.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_const_string.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_lang.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_matmul.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_sm_creation.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_cuda_jit_no_types.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_complex.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_intrinsics.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_scalar_arg.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_array.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_vectorize_decor.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_serialize.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
copying numba/cuda/tests/cudapy/test_math.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudapy
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/support.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
copying numba/cuda/tests/cudasim/test_cudasim_issues.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudasim
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_context_stack.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_driver.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_deallocations.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_runtime.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_select_device.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_detect.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_inline_ptx.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_linker.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_host_alloc.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_devicerecord.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_emm_plugins.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_array_attr.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_managed_alloc.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_pinned.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_ndarray.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_ir_patch.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_array_slicing.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_streams.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_auto_context.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_nvvm_driver.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_profiler.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_libraries.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_events.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_reset_device.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
copying numba/cuda/tests/cudadrv/test_cuda_memory.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/test_library_lookup.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/test_nvvm.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
copying numba/cuda/tests/nocuda/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/nocuda
creating build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
copying numba/cuda/tests/cudadrv/data/init.py → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
creating build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums_ext.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devicearray.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/drvapi.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/error.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/init.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/driver.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/enums.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
copying numba/roc/hsadrv/devices.py → build/lib.linux-aarch64-3.6/numba/roc/hsadrv
creating build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/threadlocal.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/init.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
copying numba/roc/servicelib/service.py → build/lib.linux-aarch64-3.6/numba/roc/servicelib
creating build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/hlc.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/common.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/libhlc.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/init.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
copying numba/roc/hlc/config.py → build/lib.linux-aarch64-3.6/numba/roc/hlc
creating build/lib.linux-aarch64-3.6/numba/roc/tests
copying numba/roc/tests/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_driver.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
copying numba/roc/tests/hsadrv/test_async.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsadrv
creating build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_gufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/run_far_branch.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_ufuncbuilding.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_linkage.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_reduction.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_barrier.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_decorator.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_atomics.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_occupancy.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_autojit.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_async_kernel.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_large_code.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/init.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_compiler.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_memory.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_matmul.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_intrinsics.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_scan.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_simple.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_positioning.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
copying numba/roc/tests/hsapy/test_math.py → build/lib.linux-aarch64-3.6/numba/roc/tests/hsapy
creating build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/numbers.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/init.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/cpython/unsafe/tuple.py → build/lib.linux-aarch64-3.6/numba/cpython/unsafe
copying numba/_random.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dispatcher.c → build/lib.linux-aarch64-3.6/numba
copying numba/_helpermod.c → build/lib.linux-aarch64-3.6/numba
copying numba/_helperlib.c → build/lib.linux-aarch64-3.6/numba
copying numba/_npymath_exports.c → build/lib.linux-aarch64-3.6/numba
copying numba/_lapack.c → build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dynfunc.c → build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.c → build/lib.linux-aarch64-3.6/numba
copying numba/mviewbuf.c → build/lib.linux-aarch64-3.6/numba
copying numba/_dynfuncmod.c → build/lib.linux-aarch64-3.6/numba
copying numba/_hashtable.h → build/lib.linux-aarch64-3.6/numba
copying numba/_dispatcher.h → build/lib.linux-aarch64-3.6/numba
copying numba/_numba_common.h → build/lib.linux-aarch64-3.6/numba
copying numba/capsulethunk.h → build/lib.linux-aarch64-3.6/numba
copying numba/_typeof.h → build/lib.linux-aarch64-3.6/numba
copying numba/_arraystruct.h → build/lib.linux-aarch64-3.6/numba
copying numba/mathnames.h → build/lib.linux-aarch64-3.6/numba
copying numba/_unicodetype_db.h → build/lib.linux-aarch64-3.6/numba
copying numba/_pymodule.h → build/lib.linux-aarch64-3.6/numba
copying numba/misc/cmdlang.gdb → build/lib.linux-aarch64-3.6/numba/misc
copying numba/pycc/modulemixin.c → build/lib.linux-aarch64-3.6/numba/pycc
copying numba/cext/dictobject.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/listobject.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/utils.c → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/dictobject.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/listobject.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/cext/cext.h → build/lib.linux-aarch64-3.6/numba/cext
copying numba/core/annotations/template.html → build/lib.linux-aarch64-3.6/numba/core/annotations
copying numba/core/runtime/_nrt_python.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/_nrt_pythonmod.c → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt_external.h → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/core/runtime/nrt.h → build/lib.linux-aarch64-3.6/numba/core/runtime
copying numba/cuda/tests/cudadrv/data/jitlink.ptx → build/lib.linux-aarch64-3.6/numba/cuda/tests/cudadrv/data
running build_ext
building ‘numba._dynfunc’ extension
Warning: Can’t read registry to find the necessary compiler setting
Make sure that Python modules winreg, win32api or win32con are installed.
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/numba
compile options: ‘-I/usr/include/python3.6m -c’
aarch64-linux-gnu-gcc: numba/_dynfuncmod.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dynfuncmod.o -o build/lib.linux-aarch64-3.6/numba/_dynfunc.cpython-36m-aarch64-linux-gnu.so
building ‘numba._dispatcher’ extension
creating build/temp.linux-aarch64-3.6/numba/core
creating build/temp.linux-aarch64-3.6/numba/core/typeconv
compile options: ‘-I/home/jetson/.local/lib/python3.6/site-packages/numpy/core/include -I/usr/include/python3.6m -c’
aarch64-linux-gnu-gcc: numba/_dispatcher.c
aarch64-linux-gnu-gcc: numba/_typeof.c
aarch64-linux-gnu-gcc: numba/_hashtable.c
aarch64-linux-gnu-gcc: numba/_dispatcherimpl.cpp
aarch64-linux-gnu-gcc: numba/core/typeconv/typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_dispatcher.o build/temp.linux-aarch64-3.6/numba/_typeof.o build/temp.linux-aarch64-3.6/numba/_hashtable.o build/temp.linux-aarch64-3.6/numba/_dispatcherimpl.o build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o -L/home/jetson/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_dispatcher.cpython-36m-aarch64-linux-gnu.so
building ‘numba._helperlib’ extension
creating build/temp.linux-aarch64-3.6/numba/cext
aarch64-linux-gnu-gcc: numba/_helpermod.c
aarch64-linux-gnu-gcc: numba/cext/utils.c
aarch64-linux-gnu-gcc: numba/cext/dictobject.c
aarch64-linux-gnu-gcc: numba/cext/listobject.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/_helpermod.o build/temp.linux-aarch64-3.6/numba/cext/utils.o build/temp.linux-aarch64-3.6/numba/cext/dictobject.o build/temp.linux-aarch64-3.6/numba/cext/listobject.o -L/home/jetson/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/_helperlib.cpython-36m-aarch64-linux-gnu.so
building ‘numba.core.typeconv._typeconv’ extension
aarch64-linux-gnu-gcc: numba/core/typeconv/_typeconv.cpp
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/typeconv/typeconv.o build/temp.linux-aarch64-3.6/numba/core/typeconv/_typeconv.o -o build/lib.linux-aarch64-3.6/numba/core/typeconv/_typeconv.cpython-36m-aarch64-linux-gnu.so
building ‘numba.np.ufunc._internal’ extension
creating build/temp.linux-aarch64-3.6/numba/np
creating build/temp.linux-aarch64-3.6/numba/np/ufunc
aarch64-linux-gnu-gcc: numba/np/ufunc/_internal.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_internal.o -L/home/jetson/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_internal.cpython-36m-aarch64-linux-gnu.so
building ‘numba.np.ufunc._num_threads’ extension
aarch64-linux-gnu-gcc: numba/np/ufunc/_num_threads.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/np/ufunc/_num_threads.o -o build/lib.linux-aarch64-3.6/numba/np/ufunc/_num_threads.cpython-36m-aarch64-linux-gnu.so
building ‘numba.mviewbuf’ extension
aarch64-linux-gnu-gcc: numba/mviewbuf.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/mviewbuf.o -o build/lib.linux-aarch64-3.6/numba/mviewbuf.cpython-36m-aarch64-linux-gnu.so
building ‘numba.core.runtime._nrt_python’ extension
creating build/temp.linux-aarch64-3.6/numba/core/runtime
aarch64-linux-gnu-gcc: numba/core/runtime/_nrt_pythonmod.c
aarch64-linux-gnu-gcc: numba/core/runtime/nrt.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/core/runtime/_nrt_pythonmod.o build/temp.linux-aarch64-3.6/numba/core/runtime/nrt.o -L/home/jetson/.local/lib/python3.6/site-packages/numpy/core/lib -lnpymath -lm -o build/lib.linux-aarch64-3.6/numba/core/runtime/_nrt_python.cpython-36m-aarch64-linux-gnu.so
building ‘numba.experimental.jitclass._box’ extension
creating build/temp.linux-aarch64-3.6/numba/experimental
creating build/temp.linux-aarch64-3.6/numba/experimental/jitclass
aarch64-linux-gnu-gcc: numba/experimental/jitclass/_box.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/experimental/jitclass/_box.o -o build/lib.linux-aarch64-3.6/numba/experimental/jitclass/_box.cpython-36m-aarch64-linux-gnu.so
building ‘numba.cuda.cudadrv._extras’ extension
creating build/temp.linux-aarch64-3.6/numba/cuda
creating build/temp.linux-aarch64-3.6/numba/cuda/cudadrv
compile options: ‘-Inumba -I/usr/include/python3.6m -c’
aarch64-linux-gnu-gcc: numba/cuda/cudadrv/_extras.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.o -o build/lib.linux-aarch64-3.6/numba/cuda/cudadrv/_extras.cpython-36m-aarch64-linux-gnu.so
building ‘numba.np.ufunc.tbbpool’ extension
compile options: ‘-I/usr/include -I/usr/include/python3.6m -c’
extra options: ‘-std=c++11’
aarch64-linux-gnu-gcc: numba/np/ufunc/tbbpool.cpp
aarch64-linux-gnu-gcc: numba/np/ufunc/gufunc_scheduler.cpp
numba/np/ufunc/tbbpool.cpp:31:2: error: #error “TBB version is too old, 2019 update 5, i.e. TBB_INTERFACE_VERSION >= 11005 required”
numba/np/ufunc/tbbpool.cpp: In constructor ‘fix_tls_observer::fix_tls_observer(tbb::interface7::task_arena&, int)’:
numba/np/ufunc/tbbpool.cpp:87:108: error: no matching function for call to ‘tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(tbb::interface7::task_arena&)’
fix_tls_observer(tbb::task_arena &arena, int mask) : tbb::task_scheduler_observer(arena), mask_val(mask)
In file included from /usr/include/tbb/tbb.h:79:0,
from numba/np/ufunc/tbbpool.cpp:15:
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate: tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3()
task_scheduler_observer_v3() : my_proxy(NULL) { my_busy_count.store(0); }
/usr/include/tbb/task_scheduler_observer.h:65:5: note: candidate expects 0 arguments, 1 provided
/usr/include/tbb/task_scheduler_observer.h:40:7: note: candidate: constexpr tbb::internal::task_scheduler_observer_v3::task_scheduler_observer_v3(const tbb::internal::task_scheduler_observer_v3&)
class task_scheduler_observer_v3 {
/usr/include/tbb/task_scheduler_observer.h:40:7: note: no known conversion for argument 1 from ‘tbb::interface7::task_arena’ to ‘const tbb::internal::task_scheduler_observer_v3&’
error: Command “aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include -I/usr/include/python3.6m -c numba/np/ufunc/tbbpool.cpp -o build/temp.linux-aarch64-3.6/numba/np/ufunc/tbbpool.o -std=c++11” failed with exit status 1
ERROR: Failed building wheel for numba
Running setup.py clean for numba
Building wheel for llvmlite (setup.py) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-li2fep0n
cwd: /tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/
Complete output (26 lines):
running bdist_wheel
/usr/bin/python3 /tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/ffi/build.py
LLVM version… Traceback (most recent call last):
File “/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/ffi/build.py”, line 105, in main_posix
out = subprocess.check_output([llvm_config, ‘–version’])
File “/usr/lib/python3.6/subprocess.py”, line 356, in check_output
**kwargs).stdout
File “/usr/lib/python3.6/subprocess.py”, line 423, in run
with Popen(*popenargs, **kwargs) as process:
File “/usr/lib/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/jetson/llvm_build_dir/llvm-config’: ‘/home/jetson/llvm_build_dir/llvm-config’
During handling of the above exception, another exception occurred:
File “/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/ffi/build.py”, line 191, in
main()
File “/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/ffi/build.py”, line 181, in main
main_posix(‘linux’, ‘.so’)
File “/tmp/pip-install-7h5wg9cg/llvmlite_20ff3c5d909b411ba56c9e06a6a0f56f/ffi/build.py”, line 108, in main_posix
“to the path for llvm-config” % (llvm_config,))
RuntimeError: /home/jetson/llvm_build_dir/llvm-config failed executing, please point LLVM_CONFIG to the path for llvm-config
error: command ‘/usr/bin/python3’ failed with exit status 1
ERROR: Failed building wheel for llvmlite
Running setup.py clean for llvmlite
Building wheel for resampy (setup.py) … done
Created wheel for resampy: filename=resampy-0.2.2-py3-none-any.whl size=321052 sha256=9783bd118a9d23ea9fcd562c257be8757de8b2b4b5865a8e51cf2919397c31b3
Stored in directory: /home/jetson/.cache/pip/wheels/cf/d4/04/49d8824a42bd9f9b11d502727965b9997f0d41d2b22ae4f645
Building wheel for scikit-learn (PEP 517) … \
