Libtritonserver.so: cannot open shared object file: No such file or directory
HW: AGX Orin
OS: Jetpack 5.1.3
I tried the following, but ended up with ERROR on libtritonserver.so is missing. There’re triton_server.cpp and triton_server.hpp found. They’re located at ~/workspaces/isaac_ros-dev/src/isaac_ros_dnn_inference/isaac_ros_triton/gxf/triton/extensions/triton/
However, the libtritonserver.so is not generated at all. Any solution to this?
Below is the command i run and the result i got.
agx-orin@agx-orin:~$ ros2 launch isaac_ros_dope isaac_ros_dope_triton.launch.py
[INFO] [launch]: All log files can be found below /home/agx-orin/.ros/log/2024-09-25-11-02-51-783634-agx-orin-72726
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container_mt-1]: process started with pid [72739]
[component_container_mt-1] [INFO] [1727233372.330269030] [dope_container]: Load Library: /home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_image_proc/lib/libresize_node.so
[component_container_mt-1] [INFO] [1727233372.379226314] [dope_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1727233372.379363181] [dope_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1727233372.384657529] [NitrosContext]: [NitrosContext] Creating a new shared context
[component_container_mt-1] [INFO] [1727233372.384977375] [image_resize]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1727233372.386433629] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1727233372.394073112] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_gxf_helpers.so
[component_container_mt-1] [INFO] [1727233372.398385072] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_sight.so
[component_container_mt-1] [INFO] [1727233372.403409622] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_atlas.so
[component_container_mt-1] [INFO] [1727233372.408950055] [NitrosContext]: [NitrosContext] Loading application: '/home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_nitros/share/isaac_ros_nitros/config/type_adapter_nitros_context_graph.yaml'
[component_container_mt-1] [INFO] [1727233372.410260290] [NitrosContext]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1727233372.414354709] [NitrosContext]: [NitrosContext] Running application...
[component_container_mt-1] 2024-09-25 11:02:52.414 WARN  gxf/std/program.cpp@514: No system specified. Nothing to do
[component_container_mt-1] [INFO] [1727233372.416194170] [image_resize]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1727233372.416252508] [image_resize]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1727233372.419034356] [image_resize]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1727233372.419152343] [image_resize]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1727233372.424359489] [image_resize]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1727233372.424474883] [image_resize]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1727233372.424957933] [image_resize]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1727233372.425791422] [image_resize]: [NitrosContext] Loading extension: gxf/lib/libgxf_message_compositor.so
[component_container_mt-1] [INFO] [1727233372.428377970] [image_resize]: [NitrosContext] Loading extension: gxf/lib/cuda/libgxf_cuda.so
[component_container_mt-1] [INFO] [1727233372.430388443] [image_resize]: [NitrosContext] Loading extension: gxf/lib/image_proc/libgxf_tensorops.so
[component_container_mt-1] [INFO] [1727233372.438524065] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container_mt-1] [INFO] [1727233372.440148578] [image_resize]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1727233372.443976848] [image_resize]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1727233372.493788197] [image_resize]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1727233372.496638303] [image_resize]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1727233372.512293822] [image_resize]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/image_resize' in container '/dope_container'
[component_container_mt-1] [INFO] [1727233372.519357837] [dope_container]: Load Library: /home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_dnn_image_encoder/lib/libdnn_image_encoder_node.so
[component_container_mt-1] [INFO] [1727233372.524754427] [dope_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::DnnImageEncoderNode>
[component_container_mt-1] [INFO] [1727233372.524862845] [dope_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::DnnImageEncoderNode>
[component_container_mt-1] [INFO] [1727233372.530387950] [dope_encoder]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1727233372.532631835] [dope_encoder]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1727233372.532706237] [dope_encoder]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1727233372.534896425] [dope_encoder]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1727233372.534977419] [dope_encoder]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1727233372.537223257] [dope_encoder]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1727233372.537330619] [dope_encoder]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1727233372.537810341] [dope_encoder]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1727233372.539977521] [dope_encoder]: [NitrosContext] Loading extension: gxf/lib/serialization/libgxf_serialization.so
[component_container_mt-1] [INFO] [1727233372.547792400] [dope_encoder]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1727233372.553611430] [dope_encoder]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1727233372.772957781] [dope_encoder]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1727233372.779016592] [dope_encoder]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1727233372.796975933] [dope_encoder]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/dope_encoder' in container '/dope_container'
[component_container_mt-1] [INFO] [1727233372.798867172] [image_resize]: Negotiating
[component_container_mt-1] [INFO] [1727233372.801147026] [dope_encoder]: Negotiating
[component_container_mt-1] [INFO] [1727233372.801253172] [dope_encoder]: Could not negotiate
[component_container_mt-1] [INFO] [1727233372.802279849] [dope_container]: Load Library: /home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_triton/lib/libtriton_node.so
[component_container_mt-1] [INFO] [1727233372.805071298] [dope_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::TritonNode>
[component_container_mt-1] [INFO] [1727233372.805131715] [dope_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dnn_inference::TritonNode>
[component_container_mt-1] [INFO] [1727233372.813943222] [dope_inference]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1727233372.817003157] [dope_inference]: [TritonNode] Set input data format to: "nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1727233372.817070742] [dope_inference]: [TritonNode] Set output data format to: "nitros_tensor_list_nhwc_rgb_f32"
[component_container_mt-1] [INFO] [1727233372.817202073] [dope_inference]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1727233372.817225817] [dope_inference]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1727233372.822337857] [dope_inference]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1727233372.822447907] [dope_inference]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1727233372.827121122] [dope_inference]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1727233372.827204676] [dope_inference]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1727233372.827795760] [dope_inference]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1727233372.832051815] [dope_inference]: [NitrosContext] Loading extension: gxf/triton/libgxf_triton_ext.so
[component_container_mt-1] [ERROR] [1727233372.834654684] [dope_inference]: [NitrosContext] dlopen failed when opening "/home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_triton/share/isaac_ros_triton/gxf/triton/libgxf_triton_ext.so": libtritonserver.so: cannot open shared object file: No such file or directory
[component_container_mt-1] [ERROR] [1727233372.834745054] [dope_inference]: [NitrosNode] loadExtensions Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1727233372.834981954] [dope_inference]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1727233372.835018435] [dope_inference]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] 2024-09-25 11:02:52.835 ERROR gxf/std/program.cpp@533: Attempted interrupting when not running (state=0).
[component_container_mt-1] 2024-09-25 11:02:52.835 ERROR gxf/core/runtime.cpp@1400: Graph interrupt failed with error: GXF_INVALID_EXECUTION_SEQUENCE
[component_container_mt-1] [ERROR] [1727233372.835097797] [dope_inference]: [NitrosContext] GxfGraphInterrupt Error: GXF_INVALID_EXECUTION_SEQUENCE
[component_container_mt-1] [INFO] [1727233372.835118213] [dope_inference]: [NitrosContext] Waiting on GXF...
[component_container_mt-1] [INFO] [1727233372.835150214] [dope_inference]: [NitrosContext] Deinitializing...
[component_container_mt-1] [INFO] [1727233372.835184231] [dope_inference]: [NitrosContext] Destroying context
[component_container_mt-1] [INFO] [1727233372.835225895] [dope_inference]: [NitrosNode] Application termination done
[component_container_mt-1] [ERROR] [1727233372.842207317] [dope_container]: Component constructor threw an exception: [NitrosNode] loadExtensions Error: GXF_FAILURE
[ERROR] [launch_ros.actions.load_composable_nodes]: Failed to load node 'dope_inference' of type 'nvidia::isaac_ros::dnn_inference::TritonNode' in container '/dope_container': Component constructor threw an exception: [NitrosNode] loadExtensions Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1727233372.847150170] [dope_container]: Load Library: /home/agx-orin/workspaces/isaac_ros-dev/install/isaac_ros_dope/lib/libdope_decoder_node.so
[component_container_mt-1] [INFO] [1727233372.854090055] [dope_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dope::DopeDecoderNode>
[component_container_mt-1] [INFO] [1727233372.854179241] [dope_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::dope::DopeDecoderNode>
[component_container_mt-1] [INFO] [1727233372.863758924] [dope_decoder]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1727233372.868125733] [dope_decoder]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1727233372.868309608] [dope_decoder]: [NitrosNode] Loading built-in preset extension specs
[component_container_mt-1] [INFO] [1727233372.873930971] [dope_decoder]: [NitrosNode] Loading built-in extension specs
[component_container_mt-1] [INFO] [1727233372.874028733] [dope_decoder]: [NitrosNode] Loading preset extension specs
[component_container_mt-1] [INFO] [1727233372.874800076] [dope_decoder]: [NitrosNode] Loading extension specs
[component_container_mt-1] [INFO] [1727233372.874841933] [dope_decoder]: [NitrosNode] Loading generator rules
[component_container_mt-1] [INFO] [1727233372.874869390] [dope_decoder]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1727233372.880137177] [dope_decoder]: [NitrosContext] Loading extension: gxf/lib/dope/libgxf_dope.so
[component_container_mt-1] [INFO] [1727233372.890965365] [dope_decoder]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1727233372.892724281] [dope_decoder]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1727233372.896013852] [dope_decoder]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1727233372.896348963] [dope_decoder]: [NitrosNode] Creating negotiated publishers/subscribers
[component_container_mt-1] [INFO] [1727233372.900684539] [dope_decoder]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/dope_decoder' in container '/dope_container'
[component_container_mt-1] [INFO] [1727233373.515063117] [image_resize]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1727233373.515239856] [image_resize]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1727233373.515301585] [image_resize]: [NitrosPublisher] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1727233373.515341874] [image_resize]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.515365875] [image_resize]: [NitrosPublisher] Use only the compatible publisher: topic_name="/resize/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1727233373.515390931] [image_resize]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.515412308] [image_resize]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/image", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1727233373.515434068] [image_resize]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.515485621] [image_resize]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1727233373.515593079] [image_resize]: [NitrosPublisherSubscriberGroup] Adjusted the compatible format of the component "input_compositor/image_in" (type="nvidia::gxf::DoubleBufferReceiver") from "nitros_image_bgr8" to "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1727233373.516048961] [image_resize]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1727233373.532879383] [image_resize]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/VIQFKZGMPC/VIQFKZGMPC.yaml"
[component_container_mt-1] [INFO] [1727233373.533028058] [image_resize]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1727233373.533128764] [image_resize]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1727233373.533163965] [image_resize]: [NitrosContext] Loading application: '/tmp/isaac_ros_nitros/graphs/VIQFKZGMPC/VIQFKZGMPC.yaml'
[component_container_mt-1] [INFO] [1727233373.542136243] [image_resize]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1727233373.542612765] [image_resize]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1727233373.542671614] [image_resize]: [ResizeNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1727233373.542866114] [image_resize]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1727233373.797827684] [dope_encoder]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1727233373.797980999] [dope_encoder]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1727233373.798019816] [dope_encoder]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.798045001] [dope_encoder]: [NitrosPublisher] Use only the compatible publisher: topic_name="/tensor_pub", data_format="nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1727233373.798073609] [dope_encoder]: [NitrosSubscriber] Use the negotiated data format: "nitros_image_rgb8"
[component_container_mt-1] [INFO] [1727233373.799566088] [dope_encoder]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1727233373.868288414] [image_resize]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1727233373.868732007] [image_resize]: [NitrosNode] Starting a heartbeat timer (eid=17)
[component_container_mt-1] [INFO] [1727233373.901425792] [dope_decoder]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1727233373.901550850] [dope_decoder]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1727233373.901570723] [dope_decoder]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.901588835] [dope_decoder]: [NitrosPublisher] Use only the compatible publisher: topic_name="/poses", data_format="nitros_pose_array"
[component_container_mt-1] [INFO] [1727233373.901600419] [dope_decoder]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1727233373.901609827] [dope_decoder]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/tensor_sub", data_format="nitros_tensor_list_nchw_rgb_f32"
[component_container_mt-1] [INFO] [1727233373.901848424] [dope_decoder]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1727233373.904317242] [dope_decoder]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/QAOLSFIFQD/QAOLSFIFQD.yaml"
[component_container_mt-1] [INFO] [1727233373.904385756] [dope_decoder]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1727233373.904398428] [dope_decoder]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1727233373.904412412] [dope_decoder]: [NitrosContext] Loading application: '/tmp/isaac_ros_nitros/graphs/QAOLSFIFQD/QAOLSFIFQD.yaml'
[component_container_mt-1] [INFO] [1727233373.906357892] [dope_decoder]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1727233373.906511079] [dope_decoder]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1727233373.906601385] [dope_decoder]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1727233373.908811798] [dope_decoder]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1727233373.909311424] [dope_decoder]: [NitrosNode] Starting a heartbeat timer (eid=67)
[component_container_mt-1] [INFO] [1727233373.911403179] [dope_encoder]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/WFJKNUFLZT/WFJKNUFLZT.yaml"
[component_container_mt-1] [INFO] [1727233373.911514989] [dope_encoder]: [NitrosNode] Calling user's pre-load-graph callback
[component_container_mt-1] [INFO] [1727233373.911545134] [dope_encoder]: In DNN Image Encoder Node preLoadGraphCallback().
[component_container_mt-1] [INFO] [1727233373.911627119] [dope_encoder]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1727233373.911648016] [dope_encoder]: [NitrosContext] Loading application: '/tmp/isaac_ros_nitros/graphs/WFJKNUFLZT/WFJKNUFLZT.yaml'
[component_container_mt-1] [INFO] [1727233373.917195840] [dope_encoder]: [NitrosNode] Linking Nitros pub/sub to the loaded application
[component_container_mt-1] [INFO] [1727233373.917432837] [dope_encoder]: [NitrosNode] Calling user's post-load-graph callback
[component_container_mt-1] [INFO] [1727233373.917458534] [dope_encoder]: In DNN Image Encoder Node postLoadGraphCallback().
[component_container_mt-1] [INFO] [1727233373.917694859] [dope_encoder]: [NitrosContext] Initializing application...
[component_container_mt-1] [INFO] [1727233373.944590862] [dope_encoder]: [NitrosContext] Running application...
[component_container_mt-1] [INFO] [1727233373.944967477] [dope_encoder]: [NitrosNode] Starting a heartbeat timer (eid=98)
Hi @HappySamuel
You are working with an old Jetpack. Isaac ROS 3.0 is based on Jetpack 6. Getting Started — isaac_ros_docs documentation
The error is related to this old version.
Best,
Raffaello
Hi @Raffaello
I am using Jetpack 5.1.3, and it’s ROS version is Humble, and the isaac_ros_dnn_inference package is of version release-2.1
Is that mean Jetpack 5.1.3 cannot use isaac_ros_triton at all ?
Hi @HappySamuel
Isaac ROS 2.1 was designed with Jetpack 5.1.2.
Please check the release notes: Release Notes — isaac_ros_docs documentation and is not tested with Jetpack 5.1.3
Is that mean i just need to downgrade to Jetpack 5.1.2, then the missing of libtritonserver.so issue will resolved automatically?
If you set up all the environments with the Isaac ROS 2.1 release, everything should be fixed. If not, please let me know.
By the way, with the hardware you are using, I personally suggest, if possible, to work with the latest version of Isaac ROS and related Jetpack that fixes many bugs and adds new features.
Best,
Raffaello
Hi @Raffaello
I tried the Jetpack 6 and Isaac ROS 3.1 before. But facing a lot of hardware unsupported & library unstable:
  1. realsense camera d435i / d455 unsupported
  2. ch341 driver unsupported
  3. logitech joystick f710 unsupported
  4. pyserial communication laggy
That’s why i am left no choice but revert back to Jetpack 5, and all issues above resolved without anything fixes needed.
I will try out your suggestion to revert back to Jetpack 5.1.2 to resolve this tritonserver issue. Besides, Is there a way to revert from Jetpack 5.1.3 to Jetpack 5.1.2 without reflashing?
Issue resolved after install Jetpack6.0 and use Isaac ROS 3.0 and above
