Well hello there!
I’m having trouble downloading the libvisionworks packages for JetPack 4.3 on my host machine; it shows an ‘Install error’ for the ‘VisionWorks on Host’ tab.
Here’s the error log from the sdkmanager terminal.
- 22:06:33 ERROR : VisionWorks on Host : Version ‘1.6.0.500n*’ for ‘libvisionworks’ was not found
- 22:06:33 INFO : VisionWorks on Host : [ Package Install Finished with Error ]
- 22:06:33 ERROR : VisionWorks on Host : [ error ]: Error when apt install failed; [exec_command]: sudo apt-get update; sleep 0.5; sudo apt-get -y install libvisionworks=1.6.0.500n* libvisionworks-dev=1.6.0.500n* libvisionworks-samples=1.6.0.500n* ; [ error ]: exit status 100; [deb_path]: /home/ptinsley/Jetson4.3/sdkm_downloads/libvisionworks-repo_1.6.0.500n_amd64.deb
I looked to see if I could install the packages (libvisionworks, libvisionworks-dev, and libvisionworks-samples) through terminal, but got the following error message.
E: Version ‘1.6.0.500n*’ for ‘libvisionworks’ was not found
E: Version ‘1.6.0.500n*’ for ‘libvisionworks-dev’ was not found
E: Version ‘1.6.0.500n*’ for ‘libvisionworks-samples’ was not found
Could this be because host is running 18.04?
Fwiw, I can install libvisionworks=1.6.0.501.
Thanks for the help!
