Dear all,
I am evaluating libVMA/Connectx-5 with UDP stream and have a performance issue apparently related to the number memory descriptor in use.
I have 20Gb/s throughput without VMA using a buffer of 128 lines of 8192 bytes. OK
I have 50Gb/s throughput using VMA with this same setup (128 lines of 8192 bytes) OK.
but that can not scale to 277 or more lines. Some packet are missed (checked with a psn). Why ? If I force the sender to slowdown, I get the data. The more I have descriptors, the more I have to slowdown
memory is allocated aligned using buffer = memalign( nLines x bufLen)
udp sockets is read in a loop: (SO_
for j < Lines
recvfrom(s, buffer + j x bufLen) so there are nLines different memory descriptors
thank you for helping
