License Manager?
I’m starting to get a reasonable number of these messages during a compile.
“pgi-f95-win64: LICENSE MANAGER PROBLEM: Failed to checkout license”
Is it a PGI network problem or my network problem?
-ralph
Hi Ralph,
Nothing comes back here to PGI, so it’s local. What type of license do you have, server or workstation? If server, is the license manager hosted on a different system? Is there more information about why the checkout failed?
  • Mat
Matt,
I’m running PVF 13.4 in VS2008 on Win7 64bit.
What I showed you is all the info I have. Windows must be doing something strange (realizing of course that isn’t unusual).
Useful to know it is local. Thanks.
-ralph
Ralph,
I will send you mail with a temp license, and instructions to get
hostid and hostname info.
The main things to check.
  1. that you installed as Admin, and placed the license into
    C:\Program Files\PGI\license.dat
    as Administrator.
  2. That you went to
    Control Panel->Admin Tools->Services
    and STARTed the PGI service AFTER the license is placed properly.
  3. When you open
    Start->Programs->PGI Visual Fortran-> Command Shells
    an run pgfortran manually, does the license fail the same way?
dave
