Dear PGI Team,
I’ve installed the newest OpenACC Toolkit and generated a license file for the machine.
Trying to compile even the simplest problem doesn’t work:
[oppel@platinum] 109 (~): pgf90 pgitest.f90
pgfortran: LICENSE MANAGER PROBLEM: Failed to checkout license
lmdiag gives the following output:
[root@platinum ~]# lmutil lmdiag -c /opt/pgi/license.dat
lmutil - Copyright © 1989-2015 Flexera Software LLC. All Rights Reserved.
FlexNet diagnostics on Mon 10/3/2016 18:01
License file: /opt/pgi/license.dat
“PGI2016-700177” v2016.1231, vendor: pgroupd, expiry: 31-dec-2016
License server: platinum
nodelocked license, locked to ethernet address “a0000300fe80” starts: 1-jan-1990, expires: 31-dec-2016
Requests from the same USER/HOST do not consume a new license
This license cannot be checked out because:
This platform not authorized by license.
Feature: PGI2016-700177
Platforms: x64_lsb <> unidev, v16.1, nv, lin-acc
License path: /opt/pgi/license.dat:
FlexNet Licensing error:-89,310
For further information, refer to the FlexNet Licensing documentation,
available at “www.flexerasoftware.com”.
The node id should be ok:
[root@platinum ~]# lmutil lmhostid
The FlexNet host ID of this machine is "“a0000300fe80 a0000220fe80 fcaa14f32bd1 fcaa14f32bd0"”
Only use ONE from the list of hostids.
Any idea?
Markus
