Lidar Calibration: Egomotion relative transform always Identity (DW_EGOMOTION_ODOMETRY), ICP works
Hi everyone,
I’m trying to run/modify the DriveWorks lidar calibration sample (calibration_hesai / lidar_calibration_sample style workflow) on my own dataset (Hesai AT128 via CUSTOM_EX plugin + CAN replay). ICP runs fine, but egomotion always returns an identity transform, so the calibration never progresses (everything stays zero / identity). I use only CAN (DW_EGOMOTION_ODOMETRY).
What I see
With m_verbose = 1 I get output like:
  • ICP pose looks plausible (small rotation + translation):
    • “Adding current ICP pose to calibration engine: … (non-identity matrix)”
  • Egomotion pose is always identity:
    • “Adding Ego-Motion pose to calibration engine: … (identity 4x4)”
So: ICP works, egomotion is always identity.
Timing looks fine
  • LiDAR timestamps are non-zero, monotonic.
  • Delta between consecutive sweeps is about 100000 µs (~10 Hz), which matches the LiDAR.
  • I logged both timestamps passed into egomotion, they are different and in the correct order.
CAN / VehicleIO inputs
I “rebuilt” the VehicleIO state update logic (by-passing):
  • I use persistent member structs:
    • dwVehicleIOSafetyState m_vioSafety
    • dwVehicleIONonSafetyState m_vioNonSafety
    • dwVehicleIOActuationFeedback m_vioAct
  • For each CAN event I update only the signals needed for egomotion: wheelSpeed[i], speedESCand frontSteeringAngle
  • I set validity/timestamps accordingly. All my validity/encoding calls return DW_SUCCESS.
  • I call:
    • dwEgomotion_addVehicleIOState(&m_vioSafety, &m_vioNonSafety, &m_vioAct, m_egomotion)
    • This returns DW_SUCCESS.
  • Logged values look plausible:
    • speedESC often ~ 1.75 m/s
    • frontSteeringAngle small around 0
    • wheelSpeed[] often ~ 5 rad/s
Egomotion compute
My getEgomotionTransform calls dwEgomotion_computeRelativeTransformation(...) and returns true (DW_SUCCESS). If it fails, I skip the sweep. But it succeeds and still outputs identity every time.
Calibration engine
  • dwCalibrationEngine_addLidarPose(&icpPose, &egoPose, ...) succeeds.
  • icpPose is non-identity, egoPose is always identity.
  • Calibration status / updated sensor-to-rig transform stays unchanged (zeros / identity).
Question
What are the typical reasons for CAN-only egomotion returning an identity relative transform even though:
  • timestamps are correct,
  • dwEgomotion_addVehicleIOState returns success and inputs look non-zero,
  • dwEgomotion_computeRelativeTransformation returns success?
Any hints on what to verify next (or minimal required signals/vehicle params for CAN-only egomotion) would be super helpful.
Jis
Here is some of the code:
Some Codeparts
Initialize of Ego Motion (DW_EGOMOTION_ODOMETRY)
// Initialize Ego Motion
          dwEgomotionParameters egomotionParameters{};
          egomotionParameters.vehicle         = m_vehicle;
          egomotionParameters.motionModel     = DW_EGOMOTION_ODOMETRY ; // nur CAN
          egomotionParameters.automaticUpdate = true;
          CHECK_DW_ERROR_MSG(dwEgomotion_initialize(&m_egomotion, &egomotionParameters, m_context),
                             "Error: Initialization of egomotion module failed.");
Initialize Lidar Self-Calibration with spoofing (overwriting the device string so the dw function accepts the lidar data)
// Initialize Lidar Self-Calibration
            CHECK_DW_ERROR_MSG(dwCalibrationEngine_initialize(&m_calibEngine, m_rigConfig, m_context),
                               "Error: Initialize calibration engine failed.");
            // Spoof: Currently, the calibration engine does not support the Hesai lidar type (Spoof: overwrite device string )
            m_lidarPropertiesCalib = m_lidarProperties;  //copy
            std::strncpy(reinterpret_cast<char*>(m_lidarPropertiesCalib.deviceString),
                        "VELO_HDL64E",
                        sizeof(m_lidarPropertiesCalib.deviceString) - 1);
            m_lidarPropertiesCalib.deviceString[sizeof(m_lidarPropertiesCalib.deviceString) - 1] = '\0';
            dwCalibrationLidarParams lidarCalibrationParams{};
             lidarCalibrationParams.lidarProperties = &m_lidarPropertiesCalib;
            CHECK_DW_ERROR_MSG(dwCalibrationEngine_initializeLidar(&m_calibRoutine,
        m_lidarInfo.sensorId,
        m_canIndex,
        &lidarCalibrationParams,
        cudaStreamDefault,
        m_calibEngine),
                               "Error: Initializing lidar calibration failed.");
            CHECK_DW_ERROR_MSG(dwCalibrationEngine_startCalibration(m_calibRoutine, m_calibEngine),
                               "Error: Starting lidar calibration failed.");
Function where egomotion tranform is computet and should be filled with non-itentity:
bool getEgomotionTransform(dwTime_t A, dwTime_t B, dwTransformation3f& poseAtoB)
        dwStatus status = dwEgomotion_computeRelativeTransformation(
            &poseAtoB, nullptr, A + m_offsetTime, B + m_offsetTime, m_egomotion);
        if (status == DW_SUCCESS) return true;
        if (status == DW_NOT_READY || status == DW_NOT_AVAILABLE) return false;
        CHECK_DW_ERROR_MSG(status, "Error: getting egomotion transform failed.");
        return false;
dwTransformation3f ego{};
bool egoOK = getEgomotionTransform(m_currentGPU.timestamp, m_previousGPU.timestamp, ego);
m_currentToPreviousRigEgo = ego;
==> this function returns true, but poseAtoB stays always Itentity!
By-Pass Part / Here m_egomotion gets fed with CAN Messages:
for (uint32_t i = 0; i < num; ++i)
dwStatus status_name = dwCANInterpreter_getSignalName(&name, i, m_aCanInterpreter);
if (status_name== DW_SUCCESS && status_num==DW_SUCCESS && num>0)
                    dwStatus status = dwCANInterpreter_getf32(&value, &timestamp, i, m_aCanInterpreter);
                   if (status == DW_SUCCESS && timestamp > 0)
                         if (strcmp(name,  "ESP_21.ESP_v_Signal") == 0)
                            m_vioNonSafety.speedESC = value * (1000.0f/3600.0f);
                            m_vioNonSafety.speedESCTimestamp = timestamp;
                            setSignalValid(&m_vioNonSafety.validityInfo.speedESC);
                            setSignalValid(&m_vioNonSafety.validityInfo.speedESCTimestamp);
if (m_lastEgoMotionAddedTime < msg.timestamp_us)
dwStatus status = dwEgomotion_addVehicleIOState(&m_vioSafety, &m_vioNonSafety, &m_vioAct, m_egomotion);
m_lastEgoMotionAddedTime = sensorEvent->timestamp_us;
CHECK_DW_ERROR(dwCalibrationEngine_addVehicleIONonSafetyState(&m_vioNonSafety, m_canIndex, m_calibEngine));
CHECK_DW_ERROR(dwCalibrationEngine_addVehicleIOActuationFeedback(&m_vioAct, m_canIndex, m_calibEngine));
Dear @Jis ,
Let me check with core team on this use case and get back to you.
Dear @SivaRamaKrishnaNV ,
could you please provide any update / did you check it yet?
Is timestamp A, timestamp B are different? Could you check it in code ?
Also, could you check if poseAtoB is identity before anuytime before dwEgomotion_computeRelativeTransformation() is called?
→ Yes, AtoB is always around 100 ms, which perfectly matches the frequency of the LiDAR (10 Hz).
Also, poseAtoB is initialized right before the use of the function dwEgomotion_computeRelativeTransformation() via dwTransformation3f poseAtoB{};.
Right now our highest guess for this issue is that the egomotion estimation is not working (see Estimation of egomotion not working (feeding reasonable data via custom CAN parser)).
Generally identity is expected from dwEgomotion_computeRelativeTransformation() when timestamps are same or if there is any failure the old transform is used from the buffer. I am assuming you have double checked it already.
Is it possible to share complete code with a virtual sensors and input data to debug at our end.
Addendum
Now estimation of egomotion is working, but there is another problem.
Fix of this topic’s issue:
  • I didn’t use all of the necessery fields in for the estimation. I didn’t test which the ones I added was necessery, but now it works:
    • m_vioNonSafety:speedDirectionESC, size, sequeceId
    • m_vioSafety: size, sequenceId, timestamp_us
    • m_vioAct: size, sequenceId, timestmap_us
Situation right now with existing problem:
  • ICP works
  • Egomotion estimation works
  • poseAtoB is calculated / not zeros
  • m_currentToPreviousLidarICP and m_currentToPreviousRigEgo (names as in original samples code) is not zeros/ not identity
  • PROBLEM: Calibration still not working (stays “Not Accepted (0.00%).”)
→ I think that might be a different topic/issue, so I will not continie this here anymore.
