I’m trying to use lidar on OIGE. However, I am stuck on two problems.
moving_target_point_cloud.7z (28.0 MB)
- Lidar cannot detect the collision-enabled model.
(I can see the detected dots when I check with a single USD file.↓)
- When I use
self._lidars.add_semantics_data_to_frame()function, the error appeared.
2023-06-26 05:00:30 [9,436ms] [Error] [carb.physx.python] TypeError: can't convert np.ndarray of type numpy.uint16. The only supported types are: float64, float32, float16, complex64, complex128, int64, int32, int16, int8, uint8, and bool.
At:
/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/utils/torch/tensor.py(31): create_tensor_from_list
/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/rotating_lidar_physX.py(177): _data_acquisition_callback
/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py(469): step
/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/world/world.py(338): step
/home/bak/anaconda3/envs/isaac-sim_22.2.1/lib/python3.7/site-packages/skrl/utils/omniverse_isaacgym_utils.py(215): step
/home/bak/anaconda3/envs/isaac-sim_22.2.1/lib/python3.7/site-packages/skrl/envs/torch/wrappers.py(239): step
/home/bak/anaconda3/envs/isaac-sim_22.2.1/lib/python3.7/site-packages/skrl/trainers/torch/base.py(167): single_agent_train
/home/bak/anaconda3/envs/isaac-sim_22.2.1/lib/python3.7/site-packages/skrl/trainers/torch/sequential.py(75): train
/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.1/OmniIsaacGymEnvsAILAB/omniisaacgymenvs/skrl_examples/moving_target_point_cloud/moving_target_train.py(147): <module>
2023-06-26 05:00:30 [9,457ms] [Error] [carb.physx.python] TypeError: can't convert np.ndarray of type numpy.uint16. The only supported types are: float64, float32, float16, complex64, complex128, int64, int32, int16, int8, uint8, and bool.
At:
2023-06-26 05:00:30 [9,473ms] [Error] [carb.physx.python] TypeError: can't convert np.ndarray of type numpy.uint16. The only supported types are: float64, float32, float16, complex64, complex128, int64, int32, int16, int8, uint8, and bool.
At:
2023-06-26 05:00:30 [9,496ms] [Error] [carb.physx.python] TypeError: can't convert np.ndarray of type numpy.uint16. The only supported types are: float64, float32, float16, complex64, complex128, int64, int32, int16, int8, uint8, and bool.
At:
How can I solve those problems?
