LiDAR self-calibration stays at 0% / Not Accepted with Hesai AT128P (custom lidar, spoofed as VELO_VLS128)
Hi everyone,
I am opening a shorter follow-up of https://forums.developer.nvidia.com/t/lidar-self-calibration-with-custom-lidar-calibration-stays-at-0-not-accepted/361520/7 because I still could not resolve this issue.
I am using DRIVE OS 6.0.10 and adapted the original DriveWorks LiDAR self-calibration sample for a custom Hesai AT128P.
What works:
  • the sample runs
  • ICP produces plausible relative poses
  • CAN-only egomotion produces plausible motion
  • dwCalibrationEngine_addLidarPose(…) and dwCalibrationEngine_addLidarPointCloud(…) are called every sweep
  • no explicit DriveWorks error is thrown during calibration runtime
What does NOT work:
  • calibration status stays at: State: Not Accepted (0.00%)
  • lidar position correction stays 0 / rotation stays identity
  • updated lidar-to-rig transform remains equal to the nominal transform
Main differences vs. the original NVIDIA sample:
  1. original sample uses IMU-based egomotion, mine currently uses CAN-only egomotion:
    DW_EGOMOTION_ODOMETRY
  2. Hesai lidar type is not supported by the calibration module, so I spoof the lidar properties for calibration:
    deviceString = “VELO_VLS128”
  3. I manually overwrite the calibration lidar properties to values matching AT128P single return @ 10 Hz:
    • spinFrequency = 10.0
    • numberOfRows = 128
    • packetsPerSecond = 6000
    • packetsPerSpin = 600
    • pointsPerSecond = 1536000
    • pointsPerSpin = 153600
So I am not sure whether the calibration routine expects the actual per-sweep point count to match pointsPerSpin much more closely.
Example runtime output:
----------Sweep: 92----------
Getting egomotion transform between time 1767810975869854 (current) and 1767810975769887 (prev) (Difference: 99967)
poseAtoB Translation [x,y,z]: 0.179061338305, 0.000031024683, 0.000000000000
Adding current ICP pose to calibration engine:
  1.000000000000  0.000295144826  0.000234345949  0.182218134403
 -0.000295420032  0.999999344349  0.001175169717 -0.005197581835
 -0.000233998944 -0.001175238984  0.999999344349  0.005856796168
  0.000000000000  0.000000000000  0.000000000000  1.000000000000
Adding Ego-Motion pose to calibration engine:
  0.999999940395 -0.000346565619  0.000000000000  0.179061338305
  0.000346565619  0.999999940395 -0.000000000000  0.000031024683
  0.000000000000  0.000000000000  1.000000000000  0.000000000000
Adding 80000 Lidar points to calibration engine.
Updated Lidar to Rig Transformation (4x4 matrix):
1.000000000000 0.000000000000 0.000000000000 3.577500104904
0.000000000000 1.000000000000 0.000000000000 0.000000000000
0.000000000000 0.000000000000 1.000000000000 0.584500014782
speedESC: 1.788888931274 m/s, frontSteeringAngle: 0.005188816693 rad, translation magnitude: 0.179061338305 m
My concrete questions are:
  1. Is DriveWorks LiDAR self-calibration expected to work at all with a Hesai AT128P when the lidar is only spoofed to the official supported types?
  2. Does the calibration routine internally assume scan geometry / model behavior of the spoofed supported lidar, so that a hybrid solid-state lidar like AT128P cannot progress even if initialization succeeds?
At this point I am less concerned about calibration quality and more about why the routine never leaves 0% / Not Accepted at all.
I can provide the modified sample code and additional logs if needed.
Thanks a lot.
Dear @Jis ,
yes – the routine assumes the spoofed lidar’s geometry and behavior so AT128P cannot progress even after initialization Succeeded with spoofed parameters.
Dear @SivaRamaKrishnaNV ,
thanks for your answer. Do you know if there is a way to make my adapted calibration sample work with our lidar?
No. it requires to add it as supported calibration device which requires changes in module to generate new shared libraries.
