I would like to use the Lidar sensor in Isaac Sim by enabling drawLines in Raw USD Properties. However, I cannot select the boxes for some reason as it unchecks itself and outputs the following error:
Coding Error: in GetMetadata at line 2323 of /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/usd/stage.h – Requested type double for stage metadatum metersPerUnit does not match retrieved type float
Is this a bug in IsaacSim? I was able to enable drawLines before in a past Isaac Sim project but now I cant for some reason.
