Limited resolution detect-camera.py in helloAIworld
I am going through the HelloAIWorld code examples and every time I try to use a resolution greater than 640 x 480 for my USB camera detection the example codes crashes. Has anyone else experienced this problem?
Jaap
You would need to look at the source code and modify width and height. Please follow the steps in Jetson Nano FAQ
Q: I have a USB camera. How can I lauch it on Jetson Nano?
Check if you can launch the mode successfully in gst-launch-1.0, ad then apply the mode to HelloAIWorld code.
