Line interleaved HDR in Jetson TX2
I would like to know if the CSI-VI-ISP path in Jetson TX2 supports line-interleaved data coming from a camera sensor, like the HDR mode in the AR0239 sensor that I described in this other question:
If it’s supported, are there any code examples and/or documentation?
Also, I would like to know if the ISP in the TX2 is capable of merging the frames in the interleaved data to produce HDR. Any code examples and/or documentation would be very useful.
I would like to know if the TX2 will work with the HDR mode of the AR0239 sensor before replacing Nano with this other SoM.
Any help would be much appreciated.
@ivan.gonzalez1
As the comment only support DOL-WDR and PWL-WDR
You may consult with sensor vendor if this sensor support those of any.
