I am trying to get line rate with two machines (A and B) connected back to back using Connect_X5 EN 100G NICs.
Machine A (Transmitting pkts)
Run DPDK pktgen: sudo ./app/x86_64-native-linuxapp-gcc/pktgen -l 0-5 -n 3 -w 04:00.0 – -T -P -m “[1:2-5].0”
Machine B (Receiving pkts)
Run DPDK pktgen: sudo ./app/x86_64-native-linuxapp-gcc/pktgen -l 0-5 -n 3 -w 04:00.0 – -T -P -m “[1-4:5].0”
Machine A is sending packets @ 52G
Machine B is receiving packets @ 16G
Here are some more information.
Dell R620 with Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz (6 cores)
Only one socket is there.
HT is disabled.
isolcpus=1-5
DPDK 18.08
Ubuntu 16.04 LTS
MLNX_OFED_LINUX-4.4-2.0.7.0-ubuntu16.04-x86_64 was installed
My questions:
Q1. Why is machine B not able to receive more than 16G packets?
Q2. PCIE capacity and status speeds are diffrent.
root:~$ sudo lspci -s 04:00.0 -vvv | grep Width
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported, Exit Latency L0s unlimited, L1 unlimited
LnkSta: Speed 8GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
As you see, speed available is 16GT/s, but only 8GT/s is used. How can I increase this? The card is installed in SLOT2_G2_X16(CPU1).
Thanks,
A
