recently I updated from CUDA 5.0 to 5.5. I have a program which uses opencv, but I run into problems when I try to compile my program since I updated CUDA.
I get the following error at the end of the compilation process: nvlink fatal : Unsupported file type ‘/path/to/opencv/lib/libopencv_calib3d.so’
The first thing I did when I saw the error was compiling and installing the newest version of opencv (2.4.6.1). The compilation of opencv went smoothly, but I still get the same error.
Does anyone know why this error occurs?
I’m using ubuntu 12.04 and gcc 4.6.
I start the compilation with the following command:
nvcc --ptxas-options=-v -arch sm_30 -lineinfo pkg-config --cflags opencv main.cu pkg-config --libs opencv -o a.out
Thanks for your reply, ryluo.
I removed the pkg-config parts and now include/link only to the libraries I’m using in my .cu-file and it’s working now. But I still don’t understand why this error occured in the first place. The pkg-config output seems to be ok (the directories are correct) + it’s working with the nvcc of CUDA 5.0.
But it doesn’t matter. I’m just happy that it’s working now. Thanks again.
